Hmm professionally fitted that, looks like it was meant to be there
Alba European
looks good man , was thinking of getting one of these a while back but didnt wanna look like one of those tools with huge boost gauges all over the place, but that looks nice. gratz
" I wait I resolution derive pleasure this " latest spammer post
---------- Post added 13-11-2011 at 04:22 PM ---------- Previous post was 12-11-2011 at 08:36 PM ----------
Finally got some time to myself today and decided to try to get an air box sorted for the new pod filter and ducted cold air set up! After heaps of measuring, deliberation and dissapointment I realized there still wasn't enough room under in the engine bay for a decent custom air box to fit.
So set about trying to figure out a solution and realized the already very small Deka battery was still an issue and robbing me of much needed space.
So decided to change its aspect from east west to north south which ultimatly pushes is futher away from the pod filter and frees up a heap more room.
So to do this the poor old battery tray had to be drilled and cut up once again. Started with drilling out the left hand side of the tray to allow the angled part of the aluminium battery holder to slot through and lock in.
Then drilled a hole for a bolt to fasten the front of the battery holder to the tray
And the end result
As you can see there's enough room to swing a cat in there, well for a polo anyway
So now to protect the entire setup from engine heat and Bob's your uncle
Good progress. I was poking around the front bumper yesterday, trying to see if there was a place near the stock intake location to duct from, but not much help. I wonder if the corrugation of the flex pipe you're using is going to slow the airflow.
Would relocating the battery to the rear of the car prove useful? Would this free up space for a decent intake path, or is there just not any decent paths whichever way you look at it?
Polo GTI MY2008 Build Thread 136.09kW and 305.28Nm torques, Dynapack Hub Dyno
Glad to hear it Mike! Are you a chance of some happy laps at lakeside?
So had another tinker after moving the battery. This time was after a place for the aluminium bell that came with the ducting to have a permanent home behind the fog lamp grill to catch some cold ram air to make the whole exercise worth while! Once again not an easy task.
First had to hacksaw off the ass end of the bell on an angle to help with fitting as there's no room behind there and the angles are super tight
Then had a bitch of a time relocating the horn assembly and adjusting its arms so the two horns actually fit still allowing the fog lamp to screw back in its hole
Then trimmed a bit more from the inside of the grill and here's the result
---------- Post added at 04:53 PM ---------- Previous post was at 04:33 PM ----------
Hey noone, yeah the ducting looks a little deceiving from the outside. Here's a shot from the inside showing how it smooths out when when fully extended as the wiring spirals around the outside. I was just waiting to see what type of air box I was going to go with before I cut the excess length off.
Happy to say decision made!
Steve from Modshack is going to custom build me a hybrid TTDA/VTDA thermal sealed airbox that allows for the 3" cold feed ducting in the front and either the stock MAF or larger OD 3" MAF in the rear.
(side note on the 3" MAF I installed - started to lose boost after a few days. Read why here
Ok so phase II of the induction project is underway!
So the plan is to get more air flow than the crappy little runners on the small port intake manifold will allow so going for the large port manifold swap off an old AGU engine. I have seen flow tests carried out on Vortex and they show the big port manifold flows about 10% better than the small port. So to do this I had to lose the SAI pump for fitment reasons so went the whole hog with the N249 & N112 delete also.
Pic of the flow test results
Here's a pic of the AGU manifold that I painted with heat resistant paint to help keep heat transfer from the engine down. See the width of the runners, much wider than the stock small port.
Also painted the TB to match!
Here is the rest of the stuff needed plus some extra goodies
So to get the manifold port matched to the head I got a Phenolic gasket in the transition port version. This sucker is thick, much thicker than the power gasket I'm running at the moment so should do a great job of stopping heat transfer!
Here's the link for those interested. They also do a small port only if you're wanting to use the stock small port manifold. Pack includes 2 normal gaskets plus the phenolic as well as longer bolts.
Now there is one more hurdle and that is the AGU manifolds fuel rail mounting holes are 11.5mm higher than the polo. So of you use the polo's fuel rail the injectors won't seat. Not even close actually as the polo uses the smaller EV-6 injectors. So Jimmy is helping out with this little issue so not worried
In the mean time completed the SAI pump delete.
So needed 3 resistors, combi valve block off plate and some coolant. Got the resistors from INA who actually sell OEM looking ones that plug right into the existing plugs so no cutting of any wires if you want to return everything back later. They look great actually
Now the ones you want to get from INA are 2 oval type (I some how stuffed that simple task up and got one oval and one square that does't fit ) The SAI plug is bigger so they don't actually make one for that so they just sell a bare 10w 300ohm resistor. So to keep from cutting any wires I just bought some 2.5mm male plugs and wired them onto the end of the resistor which just plug into the stock plug like this
So to drive the car feels more raw, alive and responsive with more induction noise also. It dosn't feel choked up in the higher revs like it used to and boost comes on a little sooner to! No CEL yet after 60 odd kms
So next is to sort out that fuel rail and install the AGU manifold and will change to the colder range thermostat at the same time as it's well hidden under the manifold. And I'm hoping the custom air box and MAF will be here in the next week too! Here are a couple of pics Steve from Modshack sent
So that intake adaptor works to allow the big port intake mani to fit to the small port engine, I've not seen much on that one... Will the stepdown over a short distance cause a restriction or turbulance? I guess the lesser of the 2 evils...
It will be interesting to see how much better it breathes with the best Polo 9N3 Polo CAI system I've seen developed and the greater intake mani flow.
When I get a jobby, I'll have to chase you on the intake initiatives...
Cheers mate! I've spoken to a couple of different vendors that sell the product and they say it will help greatly with reducing turbulance but yes it will always be more restritictive than if you went big port mani on a big port head, which Jimmy and I hope to make it happen in the future
Here are some closer snaps of the post transition section
Smooth!
Hope you get a job soon mate, but bet you're loving some time off!
Hey mate,
I saw you on Logan Rd today around 15:30. I was the one with the stupid grin giving you a thumbs up from a silver mk4 golf.
It wasn't hard to find you here, I just hit the search bar for "s*** hot polo" and yours was first on the list
I don't know how you've managed to keep it so clean with all this rain! I must say she's looking very very nice, with some impressive mods to boot. Well played sir!
Looking forward to seeing that, hope it looks like its meant to be there!!! itll be coming iun for surgery early if not
Also looking forward to seeing how the ECu copes with the resistors.
Speak to you soon mate, hopefully have a nicer surgery for the Devil next year!!!
Hmm
Jmac
Alba European
