More caster can help with minimising tamlining, plus FWD's are often very sensitive to toe settings. Different camber settings side to side can also contribute to torque steer. In order, maximise the caster, even up the camber and then I'd suggest trying a few different toe settings. Toe out will make it handle better but maybe accentuate the torque steer. So try some toe in, say 2 mm each side and see how it feels. If it mostly torque steers one way then I'd also check the wheelbase, side to side.
The most common cause of torque steer, once worn or out of alignment components is eliminated, is excessive scrub radius. With negative scrub radius the wheels tend to self align, that's why it's often found on some manufacturers FWD's. If you have changed the wheels and/or added spacers then I'd suggest checking the scrub radius. Zero or a small amount positive is OK, but too much, say 10 to 15 mm, will commonly cause torque steer.
Gary
Gary
