Tramlining & Excessive Torque Steer.
  • Tramlining & Excessive Torque Steer.
    Hoyhoy.
    To start with having done a few mods to the Pog. giving it some performance & then along with tracking & driving a bit hard at times the problem has risen, being excessive torque steer & tram-lining coming into play. So me started looking & found sub-frame movement, look what me found. (The shiny section around the bolt head is from the bolt moving which is one of two each side holding the sub-frame to the chassis via what I call hangers.)
    http://
    The reason being these bolts holding the sub-frame are 12mm & go into 18mm holes.
    http://
    Hooroo.
    Hoyhoy.
    So me had a chat with a engineer here on the Gold Coast & left it with him, here's what he came up with.
    http://
    http://
    http://
    Being adjustable is another big plus.
    First trail bought tears to my eyes, massive improvement, no more tramling & torque steer has been reduced by masses.
    I just can't say enough in words on how good it feels, with the fair amount of HP that the Little Blue Girl has now, Its the nicest thing that I have owned & just love to take her out.
    I wonder how many people have or are trying to sell their Pog's because of this reason.
    __________________________________________________ _______________________________________________
    O.K.
    Will do a small run of these, now called = Sub-frame hanger bolt cam sleeves.
    Heres a list of the interested parties, so as to get an idea of required numbers.
    h100vw - yes
    DeanB - yes
    VWindahouse - yes
    insanekiwi - yes
    gtimonkey - yes
    noone - ?
    Desmo - ?
    Ben GTI - ?
    Last edited by Eddy; 28-03-2010, 01:23 PM. Reason: Adding a list for those interested in obtaining these.
    Hooroo.
      Yep that's a good fix. I like it..
      The reason they do this is to accommodate misalignment in the manufacturing process between different parts. Oversize holes allow for a higher tolerance and things fit together easier, basically.
        Nice one Eddy that looks really good and makes heaps of sense, i love the fact that there is still adjustment so that will alllow for good fitment as VW intended but at the same time when you are happy where you are fitted , all torqued up she is tight. That with solid bushes and a well set up geometery would be a good thing.
        Good onya mate
        Jimmy
        Alba European
          Good onya mate
          Jimmy
          Hoyhoy.
          Booked in on Monday coming at Ricks for a wheel alignment, we'll see what he thinks of the set-up, along with the 3 degrees negative camber & extra castor, hey.
          Hooroo.
            Originally posted by Eddy View Post
            Hoyhoy.
            Booked in on Monday coming at Ricks for a wheel alignment, we'll see what he thinks of the set-up, along with 3% negative camber & extra castor, hey.
            Looking forward to that feedback Eddy, tell the Italian stallion im asking for him.
            Be good to see the printout mate
            Jimmy
            Alba European
              Hoyhoy.
              Will do.
              11.00 AM if your around.
              Hooroo.
                Eddy thats possible ill see how i go mate.
                Jimmy
                Alba European
                  Hoyhoy.
                  I should also say that this is not just for Polo's, but a wide range of VW's.
                  Hooroo.
                    How much were the inserts Eddy? Can you get more?
                      Hoyhoy.
                      Not only Vw but Audi too, they all fall into this trap. Your man at the lathe is going to be busy i feel
                      Jmac
                      Alba European
                        Nice work.
                        Is your engineer friend interested in starting a production line for these ?
                        I'll buy some if you head down that path.
                          Yes please Eddy count me in, and these should end up a good little earner world wide.
                            Where are you squeezing your Camber from Eddy?
                            Also have some interest in the pins.
                              Hoyhoy.
                              Now thats another story on its own with many $'s & man hours spent there, the setting in the pic. is at -2 degrees for the road.
                              http://
                              Hooroo.
