Hoyhoy.
OK people, we have talked a little bit along these lines. Will get back to ya's.
Its not just the camber pins, you need longer bolts (hard ones), 30mm slim line open ender which will have to be made as well. Also a 30mm socket for ajusting.
Rough figures will be around 140 - 170 dollars with longer bolts & the spanner including GST, no socket, plus fitting which can be straight forward, but may need to ream the holes out if damaged.
This price might scare a few off, hey, but its cheap for what it does.
This engineer chap is from the old school, not on line & hard to get to answer the Ph. So I'm not sure on how to go about it as yet.
How about I edit the opening post for those interested or start a new thread for a list of possiables,,,,, what ya's think.
Would also be interested in understanding how hard it is to get camber on the front (now that you've done all the hard work).
What sort of labor time do you think would be involved? An hour-ish? If it is going to be a long install, the price of the components ends up being less relevant to me as I have to pay a mechanic more to make the change than the cost of the parts.
Thanks Eddy, really good engineering and so greatful to you for sharing your findings.
Hoyhoy.
Well theres a lot involved, cutting of strut tower top, narrow springs (story on its own) to be able to fit in the small strut tower, top end of the sway bar links has to be changed also, because it also hits on the 3 degree setting. Camber plates were round in shape, but have to be changed to a diamond shape. A lot of minor hand filing in the top part as well. Not much room in these little things.
In hours don't know, weeks = heaps
A long episode, me fussy & me like the BEAST the way she is now.
Just to give ya an update of the lastest list of changes made.
APR tune.
KO4 Turbo.
APR dog bone bush.
APR turbo back exhaust.
APR Front Mt. Intercooler.
APR R1 diverter valve.
Forge tip.
Seat intake.
K&N panel filter.
Wheel spacers. 15mm. Front,,,15mm. Rear.
Modified Forge front strut brace.
Slotted standard brake rotors front & rear.
Green stuff pads for the road & Ferodo DS3000's for track use along with upgrade fluid.
Cut down front brake backing plates.
Front brake ducting for cooling.
Billet steel flywheel.
EVO pressure plate.
Peloquin L.S.Diff.
KW V3's coil overs, modified & with heavier springs.
Custom Camber plates by Extreme Motorsports.
Custom made heavy front sway-bar. (24mm.)
Lower Front Chassis Brace.
Custom lower control arm bushes.(Custom 95 Enduro)
Control arms bolted at rear bush to reduce movement.
Custom sub-frame hanger bolt cam sleeves.
A bit of trivia, the weight on the front wheels of the Pog is 790Kilos.
Hoyhoy.
06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
Eddy, QR sprints in September, would be tops to see the car in full flight. Would also be nice to compare a heavily modded one to a stocker, and also learn some new tricks.
Track Car: 06 Polo GTI Red Devil mkII Daily: 2010 VW Jetta Highline Gone but not forgotten: 08 Polo GTI
08 Octavia vRS Manual|DNA Stage 2 Tune|Golf R Intercooler|APR DP|Carbino Intake|Uprated DV|Porsche Calipers (NQSBBK)|Superpro Alloy front control arms and bushes|42DD Stealth Catch Can and PCV|42DD Shift Bushes|Whiteline adjustable rear sway|Superpro torque arm bush| Front and rear lower strut braces|Whitline steering rack bush|
Fair price. I should have said something earlier. Could of got in on a good deal here!
If it all falls over with your mate, let me know. I'd be interested in making them. However if all goes ahead, that's cool too. I'm not interested in undercutting anyone.
