Hi all,
I started with my Polo Gti with a chip (APR). slowly slowly added dump pipe, intake, full exhaust and Front mount intercooler. Unfortunately, Ive added my boost gauge pretty much last..
Does changing intercooler or exhaust or even intake mods effect the boost..
My car had a strange episode the other day. I changed the air intake to a POD setup and it would only boost to maximum of 17.5psi (previously would go past 20psi)
But I decided to reset it and now it boost again to over 20psi..
At the moment give my car a hot and it will boost to over 20psi (my gauge only reads to 20psi) and then stabilised to about 18psi and past 5000rpm settle down to about 14psi...
But I dont know if this was the case prior to intercooler/dump etc..
and he s*** himself
. after i tighten the forge splitter it held better.. The weird thing is the car drove hard all the way home with the splitter just after i got the flash but as soon as i fitted the boost gauge it just started to leak boost. Is it possible to have too many things attached to the vacuum system?
