2016 81TSI noise
  • 2016 81TSI noise
    So I have a new 81tsi Polo.
    When Im sitting idling in traffic (when engine hasn't turned itself off) the idle ambient noise is weird. It almost sounds like a diesel if you know what I mean. I only have 5000km on it though so wonder if its just because the engine is new. I still get the new car smell when I turn if off in garage and it still creaks as its cooling down like all new cars I have had.
    What would be causing this?
    Direct inject petrol engines have similar technology to common rail diesels in that they use a very high pressure fuel rail to deliver fuel to the cylinders via the injectors. This CAN make them sound SOMEWHAT similar to a diesel...not saying this is definitely what you are hearing but it's a possibility.
    You'd really need to post a video of it, or compare with another similar car yourself.
      Interesting.
      In comparison to the identical 81tsi I traded in 2 weeks ago it sounds nothing like it. That did have 50k on the clock though... I'll try post a video.
        Mine is dead quiet. Have you opened the hood to investigate?
          My Aug 2015 build 81TSI manual does the same - almost diesel like and only around 700-800rev idle - neither our 2013 90TSI & now 92TSI Golfs do it - otherwise the Polo engine is the sweeter. It has now done a flawless 84,000km in its first 2 years so I have assumed there’s nothing wrong with it - just that annoying niggle that the idle refinement is not as good as the rest of the car. No-one else has ever commented on it. The sound is more noticeable from in the car than outside. The best built most perfect car I’ve ever owned.
          Nov '15 Polo 81TSI manual white
            i have a 1.8 polo and it sounds like this. i asked vw since its has warranty and they compared it with similar model and its the same. hahaha. i have heard from friends who had experience with new model vw that its how its suppose to be (sounds like a diesel). its normal. still next warranty check ask them.
              So relieved that the slightly unrefined idle and diesel-like sound of my purchased 2015 81tsi aren't in my head. It is a little disconcerting at first. I mentioned it to my mechanic today when I dropped it off to have the battery replaced and connection on the headlamp checked. Hope everything else on the electrics check out and that this isn't the reason for the flat battery.
                I think mine has become slightly quieter with age - now at 140,000km.
                Maybe it’s just me getting older & deafer.
                My Polo continues its trouble free perfect run with no replacements other than the original tyres at 135,000km. No oil useage either. Best car I’ve ever owned.
