Originally posted by Bassik
View Post
DSG "False Neutral" Yesterday...
As gavs suggested, you might want to get VW to look into the noises you are hearing. The only info i can offer on this is that the brand new (had 90km on it) Skoda Fabia vRS i drove last week also had audible metallic clicking noises coming from the gearbox during gear changes. It has the same 7 speed DSG as the Polo GTI.
Yeah could be right, I'll drive it as per usual and get VW to have a look at it. I'll also get one of those other guys to do a service and cancel the VW service. Might do a little tuning.Originally posted by Lucas_R View PostAs gavs suggested, you might want to get VW to look into the noises you are hearing. The only info i can offer on this is that the brand new (had 90km on it) Skoda Fabia vRS i drove last week also had audible metallic clicking noises coming from the gearbox during gear changes. It has the same 7 speed DSG as the Polo GTI.GOLF GTI MY11 ADIDAS Candy White, Sunroof
GOLF GTI 40th ED, White with Sunroof
this may slightly OT, but I notice my DSG (at low speeds just after take off) feels like it running on corrugated road, so a slight vibration. Been doing it for a little while, and is still doing it after recent DSG update (recall 37G7)
any thoughts?White 3-dr Polo GTI
Tiguan 189TSI
Normally in 2nd gear take offs with a decent amount of throttle input, but not enough to kick down a gear? If so, new clutches.
Regarding the 37G7 campaign, all of the talk about improved gear changes, better kick down etc will be gone within 2 weeks of the update because what the campaign does is it tells the computer to fully seat the shift actuation solenoids when the car is stopped instead of sitting at a "ready to engage" position. This prolongs the life of the solenoids, that is all. The reason people get the different feeling straight after the update is because the software in the gearbox is reset. Disconnect your battery overnight and reconnect it and it does the same thing. 37G7 does not in any way influence the way the car drives unless of course you had a solenoid on its way out already.sigpic
thanks Gavs, is getting new clutches normal...I mean easy to get service to accept a wty claim?Originally posted by gavs View PostNormally in 2nd gear take offs with a decent amount of throttle input, but not enough to kick down a gear? If so, new clutches.
secondly, Yes, I did notice the "improved" stuff and yes, it has already worn off...White 3-dr Polo GTI
Tiguan 189TSI
I have been getting this recently as well. Would this have any relation to my so called gearbox issue? Something tells me that all the issues I'm having are related but really I can't need a new gearbox and clutch already... it's not even a year old?GOLF GTI MY11 ADIDAS Candy White, Sunroof
I've been getting this "shudder", for lack of a better term, too. For about a month, now.In 1st and 2nd, at low revs and especially when the car is cold. I've taken to using manual mode to keep the revs a bit higher until warm.
I haven't been advised to get the DSG update, and couldn't find the info on erWin. I thought after reading other posts that the update would resolve this. Thanks for the info on what the update actually does, gavs.
Incidentally, how DO you get this technical info that even the service guys can't seem to get their hands on? You must have some freaky connections!2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
1st Ride: 1988 Red VW Fox Sedan!
True that....Originally posted by RoknRob View PostIncidentally, how DO you get this technical info that even the service guys can't seem to get their hands on? You must have some freaky connections!
... and yes comparing the 2 cars would be putting peoples minds at ease because I have noticed the shudder as well and it's be more noticeable after software update.GOLF GTI MY11 ADIDAS Candy White, Sunroof
Honestly, you don't want to know and I'm ashamed to admit to doing it....Originally posted by RoknRob View PostI've been getting this "shudder", for lack of a better term, too. For about a month, now.In 1st and 2nd, at low revs and especially when the car is cold. I've taken to using manual mode to keep the revs a bit higher until warm.
To answer questions regarding the "shuddering" For anyone who has had a manual that has a slipping clutch or a clutch on it’s way out, you will know this feeling. Generally, it will happen when you load up the torque through the gearbox, like in a low speed acceleration out of a corner. This causes the clutch to slip against the flywheel.
Yes, it is a known issue, especially in the GTI polos. Yes, there is a fix as I have already had this fix applied to my car, it’s about a days’ worth of work. Yes, it is covered under warranty.sigpic
gavs, is there a code / reference we can quote to avoid unnecessary delays in dealership accepting claim?Originally posted by gavs View PostTo answer questions regarding the "shuddering" For anyone who has had a manual that has a slipping clutch or a clutch on it’s way out, you will know this feeling. Generally, it will happen when you load up the torque through the gearbox, like in a low speed acceleration out of a corner. This causes the clutch to slip against the flywheel.
Yes, it is a known issue, especially in the GTI polos. Yes, there is a fix as I have already had this fix applied to my car, it’s about a days’ worth of work. Yes, it is covered under warranty.White 3-dr Polo GTI
Tiguan 189TSI
What is the "fix" you had done Gavs? also as the above member asked, is there a code/reference number for this to be carried out? I've noticed my car is slipping between 2nd down to first once leaving my driveway going up quite a steep hill...its as if the car wants to cave in and die in the bum.Originally posted by gavs View PostTo answer questions regarding the "shuddering" For anyone who has had a manual that has a slipping clutch or a clutch on it’s way out, you will know this feeling. Generally, it will happen when you load up the torque through the gearbox, like in a low speed acceleration out of a corner. This causes the clutch to slip against the flywheel.
There isn't a specific service campaign but if you go into the dealership and go for a drive with the tech and you can prove the clutches are slipping then they will replace them under warranty. There has been revisions to the friction materials used in the 7spd dsg clutches to hopefully fix this issue.sigpic
Gavs, are you happy with the fix and do you consider it a permanent one...?Originally posted by Hail22 View PostWhat is the "fix" you had done Gavs? also as the above member asked, is there a code/reference number for this to be carried out? I've noticed my car is slipping between 2nd down to first once leaving my driveway going up quite a steep hill...its as if the car wants to cave in and die in the bum.White 3-dr Polo GTI
Tiguan 189TSI
Well the clutch slipping is no longer occurring so yes, is it permanent? Well I sure hope these clutches last longer than 20,000kms but realistically clutches should last in a road car to at least 150,000-200,000kms depending on use and type of compounds.sigpic
