Originally posted by ill0gitech
View Post
Whats with the removable bluetooth screen thingie?
This is the code that readerr0r has kindly provided within this BT touchscreen sigOriginally posted by readerr0r View PostYeah that's what the VCDS coding removes
To deactivate the touchscreen warning, first make sure your phones BT is off. It'll reject the coding if its connected to something.
Load up VCDS -> Select Control module -> 77 - Telephone
In Telephone go select coding and enter...
0A00000000000010
To deactivate A2DP (which stops the iPhone cutting out on MDI) and touchscreen warning enter this code instead.
0A00000001000010
I will be going to the dealership tomorrow and hopefully they will be able to do that. Shall let you guys now how it ends up. Just a quick question what does "stops iphone cutting out on MDI " refer to? Is this to allow for theiphone to charge in the MDI and at the same time connected to the BT to make calls etc
It's more of an issue with the iPhone, it routes through whatever was most recently connected. So when you plug the iPhone into the MDI unit, it'll play through that for a few seconds. But then the BT unit connects to it and takes priority over the MDI. The headunit doesn't notice this happened and still uses the MDI which now has no sound.Originally posted by k0e1 View PostJust a quick question what does "stops iphone cutting out on MDI " refer to? Is this to allow for theiphone to charge in the MDI and at the same time connected to the BT to make calls etc
Anywho it basically allows you to use the BT for calls and the MDI for charging/music. But it does disable the BT Audio function, which may be annoying if your friends want to play songs or whatever.MY16 Octavia RS 162 Race Blue Combi
Just got back from the service centre, all good got the auto-locks, BT removal (however he did say that code was the old one but not sure what was old about it, however it was done in the end), the only problem was the voice help button didnt turn into a mute button just simply made it non-functional. So not sure what happened there. But thanks to readerr0r for the codes =D
Not sure on the rcd 310 unit but on the rcd 510, if this is an issue, you can go into the setup menu>Media and uncheck the Bluetooth audio box. This should stop the changeover to bluetooth audio.Originally posted by readerr0r View PostIt's more of an issue with the iPhone, it routes through whatever was most recently connected. So when you plug the iPhone into the MDI unit, it'll play through that for a few seconds. But then the BT unit connects to it and takes priority over the MDI. The headunit doesn't notice this happened and still uses the MDI which now has no sound.
Anywho it basically allows you to use the BT for calls and the MDI for charging/music. But it does disable the BT Audio function, which may be annoying if your friends want to play songs or whatever.sigpic
I have an RNS510 and it only allows you to disable automatic switching to BT Audio, but the BT unit still tells the iPhone it can stream through it. I'm pretty sure this would be the same for the RCD510, it can't tell the BT unit to stop A2DP only to ignore it.Originally posted by gavs View PostNot sure on the rcd 310 unit but on the rcd 510, if this is an issue, you can go into the setup menu>Media and uncheck the Bluetooth audio box. This should stop the changeover to bluetooth audio.
Edit: JP_The_Grey, yes you'll need to recode it if you use a non-VW branded Bury unit.Last edited by readerr0r; 17-08-2012, 02:02 PM.MY16 Octavia RS 162 Race Blue Combi
You can search for Bury S9 cradle or Bury Series 9 cradle. A few Australian dealers around, and a few different phones.Originally posted by JP_The_Grey View PostHas anyone seen a unit similar to the VW iphone dock but for other phones? I guess if all else fails I could just get the non-VW dock and do the coding, is that correct?Mk8 Golf GTI
Search for Bury Series 9 or Bury S9 cradle. A few Australian sellers out there, and a few different models on their website. There's also an online store.Originally posted by JP_The_Grey View PostHas anyone seen a unit similar to the VW iphone dock but for other phones? I guess if all else fails I could just get the non-VW dock and do the coding, is that correct?Mk8 Golf GTI
Hi JP_The_grey,Originally posted by JP_The_Grey View PostHi djwiso, it's almost like you've read my mind!
I'm about to pick up my car (77TSI w RCD510) and was wondering the same thing - I'm in the market for a new phone as well so this would help me figure it out as well.
Thanks!
JP
The dealer was able to disable the touch screen adapter, and now my S3 is paired up with Bluetooth, phone book is loaded, and I can make/receive calls without MFD b*tching for the touch screen. It was free of charge too.
Cheers,
Id like to get my nokia to work like that, any help greatly received in what to ask the dealer for. ta.Originally posted by djwiso View PostHi JP_The_grey,
Cheers,Bury S9 XL cradle for Touch Adaptor for sale: http://tinyurl.com/hgmjc4j
Sold my Shadow Blue MY12.5 3 door Polo GTI for a WRX Hyperblue...
SPOC - 1st Four.... www.DeskDivers.com & www.PloProf.com & www.2smoked.com & www.JonWallis.com
Just ask them to disable the touch screen missing alert, easy to do with VCDS too. Then you can connect whatever phone you have over the BTOriginally posted by JonW View PostId like to get my nokia to work like that, any help greatly received in what to ask the dealer for. ta.MY16 Octavia RS 162 Race Blue Combi
