Originally posted by GTI JOE
View Post
New Polo problems - Register
dash lights up as outside light diminishes - I have noticed the red pointers are iluminated and change intensity when going through tunnels etc. Doesnt matter what position the light switch is in.MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
Thanks Guys.
As I don't have LED
but I'll check for the static cornering lights within the main light cluster with the lights and indicator on.
But it would appear that a trip to Chatswood Classic needs to be arranged to resolve at least the dash illumination as only the red needles are lit in tunnels when on DRL mode.
Trust they would be happy to do warranty work on cars from other dealers.2011 Polo GTI 5DR - Candy with Comfort Pack, RNS510 and 9W7"Beggers are not Choosers"
If you don't have LED's (DRL's) then you don't have Xenons or static cornering lights.
As far as I know you only get static corning lights with the Xenon option that also comes with DRL's.
For Joe/Gavs, my dash doesn't illumintae with the DRL's just on - only when I turn the main light switch to parkers or full. From what you said Joes this sounds to be the same as you, but Gav's it seems yours is different. Can you please confirm?
Also, goes anyone know whether the central locking can be programmed to autolock once you drive off?2011 Polo GTI - I have it, I Love It!!!!
Candy White 5 Door, Comfort Pack, Audio Pack - RCD 510, Bi-Xenons, Panoramic Sunroof
No matter what setting my lights are on...the dash is illuminated full time.Originally posted by Frostee View PostFor Joe/Gavs, my dash doesn't illumintae with the DRL's just on - only when I turn the main light switch to parkers or full. From what you said Joes this sounds to be the same as you, but Gav's it seems yours is different. Can you please confirm?sigpic
For non Bi-Xenon equiped models, the static cornering light is in the fog lights and will illuminate at speeds below (I think) 40kph and dependant on a specific steering angle.Originally posted by Frostee View PostIf you don't have LED's (DRL's) then you don't have Xenons or static cornering lights.
Yes, my dash is illuminated all the time as soon as the ignition is switched to "On". In accessory, just the needles are illuminated, looks like this is a programming thing that can be activated at the dealership.
Finally, yes, you can have automatic locking enabled at the dealership, believe it kick in at 15kph...sigpic
Mine does that. You hear the doors lock as you increase speed, around 15-20kph. But I don;t give my car a chance to lock at 20, it manage to do it around 50kphOriginally posted by gavs View PostFinally, yes, you can have automatic locking enabled at the dealership, believe it kick in at 15kph...
POLO 77TSI DSG 5D - MY11 - REFLEX SILVER - COMFORT PACK
Engine - K&N Air Filter (e-2997)
AV - Rockford Fosgate T1652-S , T1652 and P3L-S12 Sub. Alpine MRP-F600 and Alpine MRP-M500, Dynamat
Planned - lots, but the "financial manager" says NO
Here's how mine is currently setup
1. Dash lights only lit when lights are set to park or on, only dial needles are illuminatied with drl's
2. When locking car if you keep lock button held down after 2nd click the windows close
I'm happy with these settings.
The only change I'll request is programming the doors to lock at 15kmph2011 Polo GTI - I have it, I Love It!!!!
Should the Auto-Climate control display brightness also change when I change the brightness of the dash lights? Mine doesn't.
And, I think my electric mirror control had lights, but can't remember. No lights atm.
Can someone confirm this?POLO 77TSI DSG 5D - MY11 - REFLEX SILVER - COMFORT PACK
yes mirror controls should be lit redOriginally posted by broxigar1983 View PostShould the Auto-Climate control display brightness also change when I change the brightness of the dash lights? Mine doesn't.
Can someone confirm this?MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
Read in the paper yesterday that there have been some issues i think with both engines (1.2 deffinate, as it was a complaint about the 77TSI and 1.4 petrol) with misfires. Havent had that happen yet, curious if anyone else has. only time i have ever had it run rough was at startup and the update they installed when i was last in fixed that not a problem.2011 VW Polo 77TSI | Manual | Savannah Yellow | Comfort Pack | Sports Pack |
Installed: Whiteline Rear Sway Bar, H&R Springs, Resonator Delete
Called Chatswood Classic to get may engine bay rattle fixed and the Service Relationship Consultant claims he has not heard of such a problem. But nonetheless he will have someone look at it. Now that's a worry! Might have to hunt down the service bulletin to help them out. Let's hope they don't create a new problem or two during their look around.2011 Polo GTI 5DR - Candy with Comfort Pack, RNS510 and 9W7"Beggers are not Choosers"
Just drove my GTi for the first time at night and opened the glove compartment ...... no light. Could someone please confirm if there is a light? I can't seem to find it.2011 Polo GTI 5DR - Candy with Comfort Pack, RNS510 and 9W7"Beggers are not Choosers"
