New Polo problems - Register
  • Thanks for replying Umai Naa!!. It's much appreciated that you can enlighten us because you really are the only one on here that would have any knowledge about this, sales people and dealer managers are sticking their heads in the sand yet it's guys like you on teh tools that actully see, feel and dismantle these things.
    So do these electromagnetic clutches have a friction material on them or is it purely metal on metal? If it's just metal on metal, it would explain the "chirp" or squeal on engagement...
    • 4 pumps on the Polo GTI or the 4 pumps covering the 1.4 twincharger in general, ie golf 118TSI ?
      • Ok, so i just read through how the whole water pump / supercharger clutch mechanism works, indeed there is a plate with friction material on it.
        There is a solenoid that, when current is supplied to it, activates the magnetic flux in the system, pulling the clutch against the friction plate. So, could the "squeak" potentially be the actual belt slipping slightly on the drive pulley at the instant that the clutch is engaged, rather than this supposed bearings issue or the clutch slipping against the friction plate.....?
        Dav, try and spray some belt dressing perhaps on the pulley for the supercharger, see if this helps??
        • [Part quote Gavs.....
          Dav, try and spray some belt dressing perhaps on the pulley for the supercharger, see if this helps??]
          Hey Gavs and others who are interested,
          2009 Volkswagen Golf MkVI Review | Car Advice | Reviews
          Refer: post Mirsad July 12th 2009 @3.39pm
          Although there's a heap of posts to read here, one of the dealerships apparently
          applied some type of lubricant between the metal plates (not mechanical minded, so guessing they mean the water pump, clutch plate assembly) anyway this temporarily worked, but pretty sure I read another post way further down that VAG said DO NOT DO THIS, as I think it was to do with dust particles etc then sticking to the lubricant causing new problems, sorry to be vague here, but no time ATM to trawl through them all again. This is the link I first heard about this chirp/squeal issue, and the reason we cancelled our Golf TSi 118 order back in Oct '09.
          Right now kicking myself for not doing my homework after being led to believe this issue had permanently been rectified, only to read 2 days after placing our own order the post from DAV. My bad! Took 6 mths already to decide due to extra long wait....haha nothin's changed
          I am wondering How wide spread this issue is and why no class action has been taken as it looks like VWA had been pulling the old “it's just a characteristic of the car" fav. line......hmm funny how a characteristic develops after 5000+k then.....thought that was more like a warranty job? Now that was back then.....in their defense I would hope two years + down the track they wouldn't keep saying this, seems the only issue is...there STILL seems to be no PERMANENT FIX
          Current ride..MY10 Golf MkVI GTI | 5 dr | CW | < DSG >| Leather| Dynaudio | Sensors | Tint | R tails
          Current ride...MY12.5 Polo 6R GTI | 5 dr | CW | Xenons | Alcantara Leatherette /4
          • Originally posted by Reckless_Engineer View Post
            This is from the Golf mk 6 section
            Take note of AB1 post # 307.......he states his water pump has been replaced “about" 4 times, not Polo GTi obviously, just the same
            engine tuned differently.
            I know I read of another person on a different forum saying his water pump had also been replaced 4 times so far, still had the chirp.
            I am also reading guys saying after x amount of k's it mysteriously went away, one guy was up around 50000kms.
            Wonder if it will again return?
            • Lubricating the plates is bad because it's like putting oil over a clutch in a manual gearbox, you lose friction and it can cause the clutch to slip and basically destroy the clutch and friction plate.
              I think if Dav could put some belt dressing on the pulley and let it get between the belt and pulley system and if still the sound persists, it would confirm that this is indeed an issue with the fricton material on teh clutch plate.
              • In my opinion, if it were the belt, I believe VW would have released a replacement, of a different compound rubber. Something that offered a bit more traction on the pulley.
                '07 Transporter 1.9 TDI
                '01 Beetle 2.0
                • Yeah, true. But they also say there is no problem, just like cars are meant to use 1litre of nice, expensive, fully synthetic oil in 1000kms for the life of the vehicle.... and a golf r is detuned for the hot weather in Australia, yet the identical Audi s3 isn't.....
                  This is why we as owners are sceptical of VGA, because like their sales staff, all they do is lie to our faces. Unfortunately, there is only one of you and that's not enough to cover all the dealership service centres
                  • Originally posted by gavs View Post
                    Hi all,
                    I am putting together a list of all the issues I can find that may potentially inflict my car when I get it...might be worthwhile for some of you others as well.
                    Is the chirp specific to the Twin charged beasties ie does it affect a 77TSI?
                    Is the high oil use also specific to the higher performance cars?
                    The only other things I have seen on this thread that may impact me are the fuel pipe knocking, which may or may not have already been fixed at manufacture now,
                    and loss of power, which also may have been fixed with latest data flash.
                    Also a couple of minor rattles from loose clips.
                    Is there anything else that I have missed?
                    cheers
                    Sword Dude
                    2011 77 TSI Polo manual Flash Red with Sport Pack
                    2014 (MY15) 125 TDI Superb Outdoor 4x4
                    • Originally posted by Sword_Dude View Post
                      Hi all,
                      cheers
                      From what I know, the chirp only affects the twin charged turbo, don't recall it affecting the Golf TSi 90, only the TSI 118.
                      Unsure about the oil usage
                      • The chirp only applies to twin-charged cars.
                        I prefer to call it 'higher-than-normal' oil consumption. It could apply to any car, based on how it's driven, although there have been isolated cases in regards to Polo GTIs, that suggest otherwise. Either way, expect to top it up at least once in the first 15,000klms, as everything beds in on the initial running-in oil.
                        The A/C pipe vibrating on the chassis rail is one you've missed, but I can't remember which engine it applies to, as I've not had to fix one for a while. Pretty sure it was the 77TSI.
                        77TSI with DSG, stalling and erratic idle - I believe this has been rectified at the production plant, with revised ECU software, which we were uploading into earlier cars.
                        Another, was the rain-sensing wipers not sensing rain. Someone forgot to tick that box when they coded the BCM at the factory, but this can be easily rectified at the dealership.
                        '01 Beetle 2.0
                        • Originally posted by Umai Naa!! View Post
                          OK then seeing as I have a manual 77 TSI and I didn't tick the Comfort options box, my only concern may be the A/C pipes banging on the chassis which is most likely being fixed at the factory now...Sweet! Plus the usual rattles that every new car has from loosened clips in transport etc
                          thanks guys
                          Sword Dude
                          • OK, I have travelled nearly 850Km without babying my beasty and the oil level is still at just below full. Have been using D and S modes...mostly S though. Once warm, treat her like a b!@tch
                            2011 POLO GTI 3dr, Candy White, Audio-Comfort-Xenon Packs
                            MODS: H&R Sport Springs - Bilstein B12s - Whiteline Sway Bar - Milltek Cat Back Exhaust - Sparco Assetto Gara Wheels
                            • Just picked up my CW Polo GTi and can (unfortunately) confirm I have the fuel-brake-a/c line rattle. Also noticed my front fogs don't do static cornering and the dash is not lit unless you turn on your head lights - but not quite sure if they are problems. Would be grateful is someone could confirm. Cheers.
                              2011 Polo GTI 5DR - Candy with Comfort Pack, RNS510 and 9W7
                              "Beggers are not Choosers"
                              • Originally posted by saabby View Post
                                Hey saabby, firstly, congrates on your new ride and joining our forum Touch wood, I don't have any rattles or noises yet. Static cornering lights should come on temporarily when entering a corner AND when the lights are ON...they are NOT the fog lights, they are part of the main headlight assembly, just next to the Bi Xenon light. This is all assuming you have Bi Xenons? Dash lights come on when lights are on (I believe?) have you checked the dash illumination adjuster dial (just below the rotary light switch). Hope this helps
