Dealership Offerring "Upper Air Intake Service" That's Not on Service Schedule ?
  • Dealership Offerring "Upper Air Intake Service" That's Not on Service Schedule ?
    I'd appreciate any advice or experience with dealerships offering an "upper air intake service" as an extra part of the 45K service schedule for the B8 Passat TDI. I live in regional NSW so I drive a balance of rural roads and the M1 motorway.
    After leaving the vehicle for service, the dealership rang me and claimed they have found that the Passat TDI models build up "a lot of carbon" around the upper air intake and linkages that should be "cleaned out" every second service. They look at it as "preventative maintenance" for the customer at an extra $150. This added extra was never "offered" for my B7 Passat TDI
    As I didn't have the service booklet at hand, I checked with VW Australia over the phone and they couldn't find any reference to this being part of the 45K service. So there seems to be no supplement for this extra maintenance under Australian conditions.
    I'd be the last know about the inner workings of diesel motors. Maybe I'm missing something in keeping this vehicle running at its best ?
    Well have a look here at how my TDI looked after 35,000km and I had error codes for blocked intake valves.
    I cleaned it myself and now do a diesel specific intake clean every 6 months before an oil change as preventative maintenance.
    The joys of today's emissions rules and the introduction of EGR valves etc.
    P2006 error on 2015 Audi SQ5 TDI with 35,000km
    B9 Audi SQ5
      Thanks for the feedback so quickly Lucas. That's a serious amount of carbon in those photos. Do you think my Passat would look like that?
      I take my hat off to you sir, you have the ability to pull down the air intake and clean it on the bench the correct way. For $150 the dealership was only going to blast a tin of solvents through the air intake. So wouldn't that flush all the carbon down into the Passat's motor ?
        EGR off-take on the 140TDI motor is after the DPF. That will massively reduce the amount of soot at the egr valve.
          Yes the amount of buildup in my car definitely took me by surprise and I was not expecting it to be that bad on a 3yr old car with 35,000km. Granted, we did buy it 2nd hand (3yrs old and 28,000km) from Melbourne so I can only speculate that it was driven alot in Melbourne traffic.
          I dare say the intake in your Passat would be somewhere along the same lines, but the situation is made worse by lots of idling and light throttle driving (stop/start traffic etc) as the EGR opens at idle and low throttle which will make the soot accumulate more quickly. I suspect that the car I bought was regularly used in Melbourne city traffic with lots of idling and light throttle.
          The spray treatments that i am aware of are:
          Sprays that are available from Supercheap / Repco etc such as this
          Penrite P26 Diesel Foaming Intake Cleaner Aerosols 130ml | Automotive Superstore
          JLM Diesel Air Intake & EGR Cleaner 400ml | Sparesbox
          Liqui-Moly Diesel Engine Intake Decarb - 326g | Supercheap Auto
          Or machines that spray a hydrogen or water steam into the engine to loosen and dislodge the buildup such as this:
          Engine Carbon Clean NSW - Home | Facebook
          Curious to know what type of service VW are offering.
          B9 Audi SQ5
            There was no mentioned of this when I had my 45k service done last month, but being a 140TDI and 50% highway running it's probably not building up too fast.
            MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
              EGR on the 140TDI is after the catalyst and the DPF. If the system is working correctly, there should be basically zero soot circulated back into the intake. Unlike EGR systems of previous generations of Diesel engines.
                If this is accurate then this is a much better design, and also the VW dealer are trying to sell an unnecessary addition to a normal service.
                Also, im going to look at mine to see if there is any way i could have my EGR rerouted to after the cat and/or the DPF on my car to slow down the gunk buildup.
                B9 Audi SQ5
                    its accurate.
                    I’d suggest it is nigh-on impossible to convert a high pressure EGR system (which is more than likely the type used on your vehicle) to a low pressure system per the EA288 engines. You’d be better off investigating EGR-delete if it causes you problems.
                      Tried that (software remap + physical block off plate) - caused this. https://www.vwwatercooled.com/forums...ml#post1311312
                      Sounds like i'll be leaving it alone then.
                      B9 Audi SQ5
                        Hi,
                        I've just taken my car to a VW dealer in northern NSW, possibly the same that you went to, who offered the same clean for my Multivan. Same situation as you where I dropped the car & then about 5 minutes later got a phone call suggesting a upper air intake clean be performed.
                        Thing is they recommended, and completed, the same clean last time I had the car serviced. When I told them this time that the work had been done last time they were apologetic but, given it was on the job card under recently completed work when I delivered the car for today's service, it did make me wonder if this is just part of their upsell tactics rather than genuinely being required.
                        On a previous service the same dealer also tried to quote me $170 to charge my battery so I've become a little wary.
                        Cameron.
                          This is a common practice among dealerships. The first VW dealer I worked for had a deal with Wynns. The advisors would try to upsell A/C deodorizes, Throttle body cleans, and fuel treatments. The more they sold, the more bonuses they earned from Wynns.
                          Yes, the TDI and FSI engines carbon up. In my experience, the best way to deal with it is to Strip the intake side of the engine down and clean it properly. Then I would be fitting a catch can to keep the oil mist out of the intake. The oil mist is what causes the exhaust soot to stick and build up everywhere.
                          2008 Passat Wagon - 125 TDI - Black on Black - All stock, for now!
                            On the B8 Passat, the EGR takes 'cool' exhaust gas from after the DPF. It is mixed into a separate port in the head - not mixing with intake air until basically the back of the valves. The potential for any soot to make it into the intake system is greatly reduced compared to earlier designs of EGR systems. I'd be interested to see any pictures of a disassembled B8 diesel intake system that has carbon buildup.
