Fault: vehicle lighting
  • Fault: vehicle lighting
    Great, so wife tells me an error has come up on the passat alltrack. So i get home and check it out.
    Fault: Vehicle Lighting.
    Thinking it is just a bulb, start turning lights on/off. So i find that it looks like a major failure somewhere as the following don't work. Called Camberwell VW Service and am dropping car off monday morning for them to have a look at.
    FR: Headlight & indicator not working
    FL: DRL not working
    RR: rightmost brake light not working
    RL: indicator & border led not working
    anyone else experience something like this?
    2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
    2023 MY23 Nevada White Cupra Formentor VZx
    2015 Carnival Yellow Honda S660
    FL: DRL not working
    If you didn’t do any codings, it’s pretty much burned units some where.
      only codings i have done which come close to affecting the lights are HBA & HBA memory, which in reality is controlled by the camera...?
        Smells like a BCM issue
          Check the fuses, circuits are often designed with diagonal lights on same circuit.
          MK4 GTI - Sold
          MK5 Jetta Turbo - Sold
            Well if you’ve done codings. It’s hard to say then. Reverse them back. Don’t say anything.
              BCM issue?
              I did my codings back in april, a month after i picked up the car. So it has been working fine since then. If VW want to play hardball, then i will ask them to prove that my codings would cause a hardware failure like this. On a side note, does the car keep a log of coding changes?
                BCM issue?
                Well. Good luck.
                  No the car doesn't keep a log, but the VW SVM server has a copy of the factory settings.
                  BCM issue?
                    Thanks for all the replies. Worked out the dashcam wasn't working, the fuse piggyback plug had fallen out. All good now.
                      I think they don't even compare the codings vs the original to find out if you've fiddled, they just dump the original codings and test from there.
                      They reset my central electric module after my first service because my start/stop got re-enabled.
                      MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
                      MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
