Dynamic Light Assist
  • #76
    Originally posted by kamold View Post
    Is that where it uses map data to bend the lights before you get to a curve?
    YES! It is. I just tried it and holy **** it works. I manually enabled headlights and watched AFS data and sure enough before the corner the headlights are already moving. WOW.
    Edit: that being said, it seems to get it wrong more than it gets it right. I'm leaving this one off.
    • #77
      Originally posted by mythik View Post
      Right! Thanks to a generous set of circumstances I've spent a great deal of time investigating this. AU delivered Passats of any variety _do not_ have the DLA hardware in them. I've verified this with Arteon and Golf R Wolf. The coding difference between the cars with and without the proper rollers is clear. When attempting to change this setting the module notices that the motors are not present for this feature and endlessly errors.
      SO THERE YOU HAVE IT! We're able to have semi-dynamic lights, not all. The setup with the coding above is a bit blindy but better than nothing.
      [ATTACH=CONFIG]31899[/ATTACH]
      I noticed there were roller shutters when I was trying to enable DLA.
      Facing a wall, turn your car high beam on, ignition off and you can see the blockage of the light and a "U" shape shadow in the middle on the wall.
      Have a try.
      Neal
      • #78
        Lol maybe it should be called 'crazy mind of their own' AFS rather than 'predictive' ?
        • #79
          Maybe it is not connected to the Nav Data like the DSR
          • #80
            What's curious is;
            Arteon - approach car in front - blacks out car in front / keeps high beam on
            Golf R - same as arteon
            Passat - can block out left and right individually, not centre. When above situation would occur system simply turns off back to low beam.
            The setting in the module that tells the car it has a roller highbeam compatible headlight is why. This is because there isn't a roller in the headlights in the Passat B8. ALTERNATIVELY. It needs some special coding / software. I'm not certain. It just doesn't enable as it should. See my code snippet above as to what should be visible in 4B Byte 3 for DLA roller headlights.
            Anyone have an autoscan from a DLA enabled Passat B8 from Germany to compare?
            • #81
              What's curious is;
              Never know Golf R has DLA as well
              The only car in VW has DLA enabled from factory should be Arteon in Australia
              I could be wrong. Can’t remember.
              • #82
                What's curious is;
                I wonder if the parameter set for the AFS module does more than just change the startup sequence perhaps?
                • #83
                  I feel so.
                  • #84
                    What's curious is;
                    Hi
                    There is an autoscan from a VW Aerton with factory-DLA:
                    Fahrzeugtyp: 3H-VW48 (3Q0)
                    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 42 44
                    47 4B 52 5F 6C 6D 75 A5 A9 BB BC CA D6 D7
                    Fahrzeug-Ident.-Nr.: WVWZZZ3HZHE702358 Kilometerstand: 305km
                    01-Motorelektronik -- Status: i.O. 0000
                    02-Getriebe -- Status: i.O. 0000
                    03-Bremsenelektronik -- Status: i.O. 0000
                    05-Zugangs-/Startber. -- Status: Fehler 0010
                    08-Klima-/Heizungsel. -- Status: i.O. 0000
                    09-Zentralelektrik -- Status: i.O. 0000
                    10-Einparkhilfe 2 -- Status: i.O. 0000
                    13-Distanzregelung -- Status: i.O. 0000
                    14-Raddämpfung -- Status: i.O. 0000
                    15-Airbag -- Status: i.O. 0000
                    16-Lenkradelektronik -- Status: i.O. 0000
                    17-Schalttafeleinsatz -- Status: i.O. 0000
                    19-Diagnoseinterface -- Status: i.O. 0000
                    22-Allrad -- Status: i.O. 0000
                    29-Lichtsteuerung li. -- Status: i.O. 0000
                    2B-Lenksäulenverrieg. -- Status: i.O. 0000
                    36-Sitzverst. Fahr. -- Status: i.O. 0000
                    39-Lichtsteuerung re. -- Status: i.O. 0000
                    42-Türelektr. Fahrer -- Status: i.O. 0000
                    44-Lenkhilfe -- Status: i.O. 0000
                    47-Soundsystem -- Status: i.O. 0000
                    4B-Multifunktionsstg. -- Status: i.O. 0000
                    52-Türelektr. Beifahr. -- Status: i.O. 0000
                    5F-Informationselek. I -- Status: i.O. 0000
                    6C-Rückfahrkamera -- Status: i.O. 0000
                    6D-Heckklappe -- Status: i.O. 0000
                    75-Telematik -- Status: i.O. 0000
                    A5-Front-/Vorfeldkamera -- Status: i.O. 0000
                    A9-Körperschallaktuator -- Status: i.O. 0000
                    BB-Türelektronik hinten links -- Status: i.O. 0000
                    BC-Türelektronik hinten rechts -- Status: i.O. 0000
                    CA-Schiebedachelektronik -- Status: i.O. 0000
                    D6-Lichtsteuerung links 2 -- Status: i.O. 0000
                    D7-Lichtsteuerung rechts 2 -- Status: i.O. 0000
                    Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\5Q0-937-08X-V2.clb
                    Teilenummer SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
                    Bauteil: BCM PQ37BOSCH 034 0242
                    Revision: -------- Seriennummer: 865821041700P1
                    Betriebsnr.: WSC 00015 115 08193
                    ASAM Datensatz: EV_BodyContrModul1UDSBosc 018001
                    ROD: EV_BCMBOSCH_018.rod
                    VCID: 065464E2A8A99D07616-8052
                    Steuergerät für Wischermotor:
                    Subsystem 1 - Teilenummer SW: 3G1 955 119 A HW: 3G1 955 119 Labeldatei: DRV\5QX-955-119-V1.CLB
                    Bauteil: WWS 170401 042 0607
                    Seriennummer: 170419161555
                    Codierung: 0E4DDD
                    Sensor für Regen- und Lichterkennung:
                    Subsystem 2 - Teilenummer SW: 81A 955 547 A HW: 81A 955 547
                    Bauteil: G397_RLFS H06 0002
                    Seriennummer: 20227625X81A955547A0
                    Codierung: 00006E
                    Lichtschalter:
                    Subsystem 3 - Teilenummer SW: 3G8 941 633 HW: 3G8 941 633
                    Bauteil: E1 - LDS MQB H01 0032
                    Seriennummer: 22 02 2017 10000613
                    Geber für Luftfeuchtigkeit: innen:
                    Kein(e) Fehlercode(s) gefunden.
                    Adresse 10: Einparkhilfe 2 (J446) Labeldatei:| DRV\5Q0-919-294.clb
                    Teilenummer SW: 5QA 919 294 B HW: 5QA 919 294
                    Bauteil: PDC 8 KanalH07 0044
                    Seriennummer: 000308418617095
                    Codierung: 0471151811
                    Betriebsnr.: WSC 05311 115 00073
                    ASAM Datensatz: EV_EPHVA18AU3700000 009035
                    ROD: EV_EPHVA18AU3700000.rod
                    VCID: 4BC295D6F34BA06FFE8-801E
                    Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5G0-920-XXX-17.clb
                    Teilenummer SW: 3G0 920 791 C HW: 3G0 920 791 C
                    Bauteil: KOMBI 405 3193
                    Codierung: 07A4101BFF84000801806B031001000880000000
                    Betriebsnr.: WSC 00015 115 00001
                    ASAM Datensatz: EV_DashBoardVDDMQBAB 009058
                    ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
                    VCID: 290E0F5E5977927F2C4-807C
                    Adresse 19: Diagnoseinterface (J533) Labeldatei:* Keine
                    Teilenummer SW: 3Q0 907 530 C HW: 3Q0 907 530 C
                    Bauteil: GW MQB High 515 5286
                    Seriennummer: 23041710800233
                    Codierung: 030300047F085900FB00827E9C0F0001000107000000000000 0000000000
                    ASAM Datensatz: EV_GatewNF 013020
                    ROD: EV_GatewNF_VW27.rod
                    VCID: 2F3AE1466793FC4FF20-807A
                    Generator:
                    Steuergerät für Multifunktionslenkrad:
                    Subsystem 2 - Teilenummer SW: 5G0 959 442 K HW: 5G0 959 442 K Labeldatei: DRV\3C8-959-537.CLB
                    Bauteil: E221__MFL-DC1 H17 0040
                    Seriennummer: 46170001122840117166
                    Codierung: 2DFFFF
                    Steuergerät für Batterieüberwachung:
                    Subsystem 3 - Teilenummer SW: 5Q0 915 181 J HW: 5Q0 915 181 J
                    Bauteil: J367-BDMConti H03 1050
                    Seriennummer: 7588600000170420035C
                    Analoguhr:
                    Subsystem 4 - Teilenummer SW: 3G0 919 204 C HW: 3G0 919 204 C
                    Bauteil: Analoguhr 209 2002
                    Adresse 29: Lichtsteuerung li. (J101 Labeldatei: 8V0-907-399.clb
                    Teilenummer SW: 8V0 907 399 B HW: 8V0 907 399 B
                    Bauteil: LCM_MLBevoH08 0014
                    ASAM Datensatz: EV_LCMLeftHELLAAU736 001012
                    ROD: EV_LCMLeftHELLAAU736_VW48.rod
                    VCID: 45D6A3EED52F561F28C-8010
                    Adresse 39: Lichtsteuerung re. (J1023) Labeldatei: 8V0-907-399.clb
                    ASAM Datensatz: EV_LCMRightHELLAAU736 001012
                    Adresse 4B: Multifunktionsstg. (J745) Labeldatei:* Keine
                    Teilenummer SW: 3Q0 907 338 HW: 3Q0 907 338
                    Bauteil: FCM MQB Low 001 0285
                    Seriennummer: 27041710802533
                    Codierung: 000000050100045207106F0502000000000000000000000000 0000000000
                    Betriebsnr.: WSC 05311 000 08193
                    ASAM Datensatz: EV_MultiModulContiVW48X 001010
                    ROD: EV_MultiModulContiVW48X_VW27.rod
                    VCID: 72BC2832B42191A75DE-8026
                    Adresse 5F: Informationselek. I (J794) Labeldatei:| 5G0-035-MIB-HGH2.clb
                    Teilenummer SW: 5NA 035 022 HW: 5NA 035 022
                    Bauteil: MU-H-LND-EU H51 1077
                    Seriennummer: A846D0HB003010
                    Codierung: 02840301000000005111010200880A101F010AE4012004009E
                    ASAM Datensatz: EV_MUHig4CGen2HBAS 001001
                    ROD: EV_MUHig4CGen2HBAS_VW37.rod
                    VCID: 70B8223ABA2DA3B7ABA-8024
                    Anzeige- und Bedienungseinheit 1 für Informationselektronik:
                    Subsystem 1 - Teilenummer SW: 5G6 919 606 HW: 5G6 919 606
                    Bauteil: ABT_High-2 H50 9120
                    Seriennummer: VWZ6ZHT1290422
                    Datenträger:
                    Subsystem 2 - Teilenummer SW: V03 959 800 QQ HW: -----------
                    Bauteil: ECE 2017 --- 0157
                    Seriennummer: --------------------
                    Compact Disc Datenbank:
                    Subsystem 3 - Teilenummer SW: V03 959 800 EG HW: -----------
                    Bauteil: Gracenote2 --- 1015
                    Adresse A5: Front-/Vorfeldkamera (R242) Labeldatei:| DRV\3Q0-980-65X-A5.clb
                    Teilenummer SW: 3Q0 980 654 J HW: 3Q0 980 654 A
                    Bauteil: MQB_B_MFK H07 0273
                    Seriennummer: 21041712P13099
                    Codierung: 0004080400000401002223448150A90094000E300040
                    ASAM Datensatz: EV_MFKBoschMQBB 001001
                    ROD: EV_MFKBoschMQBB_VW36.rod
                    VCID: 3E24CC02B0F905C7696-806A
                    Adresse A9: Körperschallaktuator (J869) Labeldatei: Keine
                    Teilenummer SW: 3G8 907 159 HW: 4H0 907 159 A
                    Bauteil: SAS-GEN 2 H07 0003
                    Seriennummer: 170407203707
                    ASAM Datensatz: EV_SoundActuaGen2AU64X 003010
                    ROD: EV_SoundActuaGen2AU64X_VW26.rod
                    VCID: 71BE273EB127AABFA44-8024
                    Adresse D6: Lichtsteuerung links 2 (A31) Labeldatei: 7PP-941-572.clb
                    Teilenummer SW: 7PP 941 572 AB HW: 7PP 941 572 A
                    Bauteil: LED1L H09 0003
                    Betriebsnr.: WSC 00000 000 00000
                    ASAM Datensatz: EV_LEDModLeftMELCOAU736 001004
                    ROD: EV_LEDModLeftMELCOAU736_VW48.rod
                    VCID: 167434A2F8092D87916-8042
                    Adresse D7: Lichtsteuerung rechts 2 (A27) Labeldatei: 7PP-941-572.clb
                    Bauteil: LED1R H09 0003
                    ASAM Datensatz: EV_LEDModRightMELCOAU736 001004
                    Ende--(Dauer: 02:44, Batt.-Spannung Start/Ende: 11.7V/11.8V. VIgn 11.9V)---
                    Hope it helps you
                    Regards
                    • #85
                      Originally posted by murmeltier View Post
                      Hi
                      Hope it helps you
                      Regards
                      Thanks for that are you also able to get an adaptation channel map from the A5 camera module and 4b led controller?
                      • #86
                        Yeah of course. I uploaded everything to my website, because it wasn't possible to upload a *.csv file here...
                        VW Aerton, MY2017 - VCDSSchweiz
                        Hope it will help you. Until now I never had a MY2018 to code...
                        • #87
                          Hi Guys
                          There's also a rainy day mode with the Arteon which can be set to auto to change the light setting when it's raining. Only have OBD11 but if you need a download, just tell me how to do it, and happy to share as you all have helped immensely with your posts to get a bunch of stuff working on my Arty.
                          Sent from my SM-G935F using Tapatalk
                          • #88
                            If this option is available in the Golf and Tiguan... why does the Passat miss out?
                            _____________________________________
                            MY09 Passat 125tdi Wagon, White, RNS510, Tint, Bluetooth
                            • #89
                              If you read the thread you'll find it was first enabled on Passats
                              • #90
                                I enabled Rain Mode once. Barely noticed the difference in the rain. Checked full speced EU Passat and they don’t enable this function. Thus, I kept it disabled.
                                The thing is Passat has fog lights and all the Audi and Arteon don’t (all weather lights instead).
                                Rain Mode and All Weather lights can be easily replaced by fog lights, can’t they?
                                Same functions different looks.
                                You can enable all modes and weather lights in the codings. You need to try and see if there are differences.
