2010 Handbrake Error
  • 2010 Handbrake Error
    We are getting a handbrake error. When it happened the first time we were able to clear it by turning the motor off then re starting. Doesn't want to clear now. Is this a common problem and is there anything a guy more used to 1968 aircooled tech is able to do about it? Any suggestions appreciated.
    Cheers.......Wayne
    You need to get a scan for faults.
    I had a problem that turned out to be the electric park brake module so I replaced it and all good.
    But the scan will tell you.
    Normally it's just the button which is an easy replacement.
    If you need a new epb module let me know as I have a spare.
    Sent from my HTC 10 using Tapatalk
      Thanks!
        Turned out to be the switch
          Good result that's the case in 90% of these issues as I understand it.
          I have a spare newer rev switch now that I've replaced it with the b7 version if anyone needs one.
