Nos, I'm not really sure about lifespan. I guess it depends alot on your driving style
R36 Brakes
Originally posted by Umai Naa!! View PostWhat brands are they?
Snerlo, I'll try giving it a bit of a run around and see if it makes any difference. It seems to only be coming from the front.
It's weird that it makes the sound without braking, and the moment I brake, it goes away :\.Biscay Blue Volkswagen R36 MY09
Don't the brakes come on gently for a couple of seconds automatically after you start going to wash water/snow of the rotors or something?
Sent from my HTC One_M8 using Tapatalk2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
It's probably the pads themselves making the noise.
Do try giving it a few good hard stops, and see how you go.
Brake wiping works in conjunction with the rain/light sensor from memory. So if it thinks there's rain, the ABS will pulse to give the brakes a quick skim.'07 Transporter 1.9 TDI
'01 Beetle 2.0
Hi guys,
I seem to be having trouble tracking down the dimensions and size of the front and rear rotors on theR36.
Are they just the same as any other V6 highline?
There is company in the USA where I get my pads and rotors , for my Jetta and Reg, awesome, huge life, almost no dust, and great stopping power.
But for some reason the R 36 seems be unknown to these guys in the USA and our VINs don't work there coz we use ZZZZs and they use that space for model options.
Anyway, if anyone can post a spec , diameter, PCD, thickness or even an equivalent model ( like the v6 highline)
I'd really appreciate it , coz my R36 will be due for a set of pads and rotors all round, and I love the ceramic pads I get from Stoptec in the US.R36 | Biscay Blue, Jetta V GT (Golf GTi with a boot really), Touareg T5 Luxury (300,000 K's and going strong)
Have you tried looking in some of the other manufacturers catalogues and giving Stoptech those partnos to find the equivalents? That might work.
eg: ATEcarandimage The place where Off-Topic is On-Topic
From here: http://www.vwwatercooled.com/forums/...ml?pagenumber=
Brakes
Brake disc front (ATE 24.0125-0158.1)
Diameter: 312mm Vented
Finish: High-carbon Surface coated
Brake disc thickness: 25mm
Minimum thickness: 22mm
Height: 49.9mm
Centering diameter: 65mm
Inner diameter: 146mm
Brake pads front (ATE 13.0460-7184.2)
Brake disc front (ATE 24.0130-0115.1)
Diameter: 345mm Vented
Brake disc thickness: 30mm
Minimum thickness: 27mm
Height: 49.9mm
Inner diameter 140mm
Brake pads front (ATE 13.0460-7200.2)
Brake disc rear (ATE 24.0112-0219.1)
Diameter: 310mm Vented
Brake disc thickness: 22mm
Minimum thickness: 20mm
Height: 48.5 mm
Inner diameter: 169mm
Came in very handy for me when getting a RWC and the mechanic tried to tell me my near brand new discs were undersized....sigpic
Originally posted by Umai Naa!! View PostWith the rears, you need a scan tool with EPB capability, and the 3-pinned caliper wind-back tool.
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
