Greetings,
Swapped B6 climatronic to B6/B7 as the temp dial was playing up. Physically an easy job however I'm slightly confused about the newer B7 unit settings. In the B6 when the yellow ECON light was ON the A/c was OFF. When the the ECON light was OFF the A/c was actualy ON. With A/c ON I was getting good temp. out readings - say around 4-6C.
my old B6 climatronic
B7 unit - with the light OFF it says the A/c is OFF (opposite to B6). With the yellow A/c light ON the unit is showing ON - again opposite to the B6. Perhaps I'm confusing here this yellow light with the B6 yellow ECON light.
So, Ok I could understand the B7 uses different approach here but how do you explain that now whether with A/c ON or OFF the best cooling I get is 10-12C? So, with the temp selection set to minimum (low) even now in winter I can not get much in the way of cold air coming out. I should add that I did read few of the climatronic related posts and upon fitment I did run HVAC reset & calibrate program.
B6/B7 unit
The other thing I noticed is that with one of the A/c settings (ON or OFF I can't remember which one now) there does not seem to be any air coming out of the centre consol face air outlets. Any ideas?
B6/B7 unit
