B7 Retrofitting - MIG's Passat
  • #46
    Great thread mate, love the updates and photos. Nice work!
    • #47
      Originally posted by kamold View Post
      Nice one I have that to do soon when I can find the time.
      Have you logged timing pull before and after the clean?
      I'm hoping it will help with this as mine is pretty aggressively pulling timing (10 degrees) at the moment.
      Nah, I don't have a timing log, the main issue I was having was cold misfires under light throttle low RPM, eg the onramp onto the freeway.
      Idle seems much smoother, will see about fuel economy.
      I can check the timing out now, what measuring value would you like?
      • #48
        You need to log RPM, ign angle retard per cylinder, air mass, throttle valve position, ignition angle.
        Ideally in 3rd or 4th under load to max RPM.
        • #49
          About to start posting again, watch this space.
          Here is a teaser
Name:	Screenshot 2023-10-17 141416.png
Name:	Screenshot 2023-10-17 140322.png
          • #50
            Here is a teaser
            [ATTACH=CONFIG]55496[/ATTACH]
            [ATTACH=CONFIG]55497[/ATTACH]
            OK, I’ll bite.
            What are you up to now?
            • #51
              Current project status
              7N0 radar is now in and working; I will do a write-up and share CAD models shortly
              Upcoming or looking into
              - Kessy retrofit
              - CC rear power sunshade
              - New front seats
              - Power boot opening.
              - Steering wheel (I have not made up my mind what one yet)
              - Installing my custom gateway under the drivers seat (Where the BT module was) and tap into the existing overhead buttons
              • #52
                Nice one Mig, look forward to the radar blog...
                I remember seeing a good write-up on many things Passat including rear blind at CBX RNS510 & Accessories: Passat Everything (jimmy-cbx.blogspot.com) (you may have seen it).
                R36 Wagon MY2010.5: Biscay Blue| Dynaudio and Nav| RVC| VW tow bar|
                Mod highlights:
                ECU and DSG Tune| 3AA CCM and 7N0 Gateway| 3D colour MFD| MIB2 retrofit and 7N0 RVC| Quad LED tail, brake and indicator rings| Zimmermann Sportbrake rotors, composite pads| TPMS High| 2Q0 Blind Spot and RCTA| B8 rearview mirror|
                • #53
                  Ok, after driving with the 7N0 radar for a few months, I might as well do the write-up.
                  The newer 7N0 radar is used in the newer PQ-based Sharan, Passat NMS and a few others.
                  These radars can be found online for about $75AUD with the mounts now, 2K5907561B, 3Q0907561C can also be converted to the 7N0907572C
                  After the component protection fix became public, I was pretty keen on the upgrade.
                  Parts needed.
                  Passat with MED17 ECU, or emulator for the can signals needed
                  ABS unit that supports ACC
                  7N0907572C ACC module
                  Custom mounts for the Passat
                  1-1534229-1 connector
                  u-Link NT (JTAG programmer)
                  Harness (I just made it up, as it's only can lines, power and ground)
                  First up was flashing the software and applying the patch to the unit.
                  Then I made some custom mounts out of some aluminium and 5mm riv-nuts
                  Basic alignment was done via a laser level, matching the car's thrust angle, the towbar's middle, and the front grill's centre.
                  In my case, I had an error trigger each time the car used the Follow to stop feature; it would apply the handbrake and log an error to do with ACC acceleration. Shout out to the amazing Kamold for helping me with that one.
                  Flashing the ECU fixed the issue.
                  So, after a few months of using it, how is it?
                  Well, as others say, the range is a bit shorter, but in practice, this does not make much difference; the unit has way better wide-angle tracking; for example, it accelerates again when the car in front moves out of your lane much quicker. The FTS feature is more refined in start-stop traffic, and you get a little too-close warning when you start tailgating.
                  This is also a much cheaper alternative to using a 3AA radar, as those radars are getting stupidly pricy on the used market.
                  • #54
                    I'm really happy with the enhanced performance over previous gen, particularly with following cars through curves where the 2nd gen radar would quickly lose lock.
                    The hardware is the same (Bosch MRREvo) as is used in the MQB cars like Mk7.5 Golf, B8 Passat etc. (was also used in other brands including Tesla).
                    So it's got at least 10 years of software and hardware improvements over the previous generation.
                    • #55
                      I love your DIY ADAS Calibration tools!!! Well done, love following this thread!!!
                      • #56
                        100%, the unit is much more refined in every way, which makes getting stuck in traffic way more calm lol.
                        Interestingly, the TRW Autocruise family of radars the old unit was from, was announced in 2004 for the Phaeton, and even had follow-to-stop feature back then.
                        Nearly have the full set now , handy tools to have. Lucky VW has not changed their ADAS boards and tools that much over the years, or even in some cases integrated auto-calibration in some of the newer modules eg (2Q0 side assist modules)
                        • #57
                          Rear climate control and heated seats are in, also installed the 230v invertor, with all this stuff added will probably need the 180A alternator next
                          [ATTACH=CONFIG]55099[/ATTACH]
                          [ATTACH=CONFIG]55100[/ATTACH]
                          In other news, I've completed the valve cover gasket replacement and PCV valve upgrade. While I had everything open, I took the opportunity to inspect the intake valves. Now I'm in the process of gathering the necessary equipment for a thorough walnut blasting
                          Video of the carbon buildup 2023 02 06 11 49 23 - YouTube
                          [ATTACH=CONFIG]55101[/ATTACH]
                          [ATTACH=CONFIG]55102[/ATTACH]
                          Still got plenty more to do
                          Hey MIG, regarding to the rear climate panel and the socket, may I know other than the two hardwares what else is needed for the installation? How does the rear panel communicate with the front one? I am trying to replicate this on my B6 R36.
                          Thanks in advance!
                          • #58
                            Thanks in advance!
                            The rear climate was a bit of a money hole. started with just the panels, then the trim did not fit the centre console, then there was no blanking plate for the inverter, so I ended up upgrading everything lol, all the parts were sourced from the Magotan, the Chinese Passat B7, that also had an extended wheelbase limo model.
                            • #59
                              Here are some sneak peeks of what is in the current pipeline.
                              • #60
                                Hey MIG did you end up recording any videos at all? GW with the upgrades
