I'm about to rotate the tyres on my B6 Passat. A mechanic told me I might have to use VCDS to tell the tyre pressure monitoring system that the wheels are now in different positions. I wouldn't have thought this is necessary?
Does anyone know?
The tpms sensors are not separately identified.
The tpms receiver must have some way of differentiating based on timing of the signals along with wheel speeds.
I swapped my sensors for newer B7 sensors and direct tpms module (shows individual pressures per tyre) and there was no calibration or identification required.
Sent from my HTC 10 using Tapatalk
2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC| 2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|3D colour cluster|Quad LED tail rings|Climatronics upgrade|Dynaudio retrofit|B7 RLine Flat Steering Wheel|3AA CCM|TPMS Direct|B7 Adaptive Cruise with Front Assist|Discover Media retrofit|PLA 2.0|Lane Assist|BCM retrofit|High Beam Assist|DQ500
Maybe I should call the sensor in the wheel arch "antenna", whatever, that's what I meant.
I have a PDF doc in my computer explains how VW TPMS works. I'd love to upload once I am on the computer.
"VW along with most other manufacturers fit antenna’s in the wheel arches which serves two purposes, the transmitters can have lower power output which means longer battery life/lighter weight and moving wheels around doesn’t require reconfiguration of the sytem."
2018 BMW 125i M Sport |AlpineWhite|719M JetBlack|BlackLeather |ComfortPackage|Sunroof|WirelessCharging
2010 MY10 R36 Wagon | Biscay Blue | Power Tailgate | RNS510 | MDI | RVC | 51,000 km |Garage Open Button | Dead Pedal Mod | OE Fit DRL | VCDS | Sprint Booster | H&R Rear Sway Bar | Alcantara Steering Wheel | Dual Reverse Light | 19" Bentley Wheels (BBS Forged Split) | Michelin PS 4S
2005 MY05 AH Astra HatchBlack | Facelifted SRi Looking | OpeliZed | Whiteline RSB | Eibach ProKit
Thought the ones NOT with wheel sensors work with the ABS and read the difference in revs from the others when it gets a flat and if so throws up a warning. Mine hasnt got the flash one and Manual says thats how it works. Had to recalibrate when I put the unused spare on the front right
B6 and B7 high use direct tyre monitoring, not the indirect method via abs like in the Golf etc
According to my manual and the buttons in the car I have tyre pressure monitoring display which checks the cicumference of the tyre via ABS and alerts to any discrepancy Has to be reset when changing tyres
Havent had a puncture but got a warning when i put the spare on as it was 3mm less worn
Havent had a ucture but got a warning when i put the spare on as it was 3mm less worn
That's tpms low (indirect).
B6 only had direct tpms. I have retrofitted the B7 tpms high 2hich shows individual tyre pressure in the MFD.
