Hey guys so me Mechatronic is posting errors which is causing the engine light to flare up.
I have taken it to get the error codes read and apparently its either a faulty Mechatonic or Solenoid issue.
Essentially when changing from Park to Reverse or the other way, you can hear the gearbox try to engage the gear but it makes about 3-5 cluncky noises and then the gear indicator disappears and the car will just Rev freely and not move.
When this happens i have to turn the car off and back on again then it works fine...
Luckily I have 2 Passat CC's, the first one's Air manifold literally exploded and was all cracked. So I swapped the air manifold on the mechatronic failure one to the one which only had a cracked manifold.
Should I buy another manifold and install it in the broken DSG one then try to sell it? What would be a reasonable amount?
Also anyone else ever suffered from a unexpected gearbox failure???
Sorry for the long winded post with multiple issues!
