Okay,
2009 VW Passat CC 2.0L TDI (CBBB engine).
The tyre pressure warning light (on speedo) has been on for a week now - starts flashing (amber) when key put in and car started, then after 30s or so it just stays put on the dash (amber).
Tyre pressures all fine (have checked) and have tried re-setting with switch on centre console to set on high and low pressure settings - makes no difference.
Have read a bit about this here and elsewhere, but I get a bit muddled with all the info on how to fix this "non-critical" but annoying problem...
So, used Foxwell scanner (don't have VCDS) and get:
"Tire Pressure - 01521 - Sensor for Tire Pressure - sporadic 004 - No signal/communication"
Now, not quite sure how tyre pressure is sensed on each wheel and what needs to be done - read about older style direct TPMS and newer style indirect TPMS (uses ABS sensors on each wheel to measure rotational speed - flat tyre rotates more than others). Is there a step-by-step process of elimination to follow in order to find the suspect part/s?
Hope someone can shed some clarity on this.
Thank you for any help/assistance.
