Tiguan Tuning Starts !
  • stoked either way! low 6's with a proper launch would be about right i reckon... but it's just a figure at the end of the day
    EDIT: does the G-Tech do 60foot times?! would be very cool if so... I did a 2.066 60', but reckon I could get into the 1.9's thinking back
    • How did the dyno day go Sharkie?
      Saw the pic of your tig on the rollers in the dyno thread.
      Did you remove the haldex unit to make it FWD only?
        The dyno was off by about 10% across all the cars from other previously known figures ..... for most that was OK as they had other similar cars to compare against but the Tig was on its own ....
        Still, it was the 3rd most powerful car there ... after the 2 APR Stg 3 cars ..... (took the Stg 3 S3 for a drive and I can see a Stg3 kit in the Tigs future .... )
        Made more than 10HP than the heavily tuned APR 190kw Polo and the tuned R32s ....
        I think everybody was .... ".... what is a SUV doing here...." and then after its run .... "... OMG its got more power than anything else (excluding the Stg3s) here !!!! ... "
        Haldex, is easy, unplug 1 plug at the rear turns it into FWD ... then afterwards, plug in and with VAGCOM clear the codes ....
        • Nice work!
          Stage 3 would be awesome on the Tig but I just couldn't justify the costs for a car that will probably only see the track once a year if that.
          Would definitely be a force to be reckoned with though.
          And good work showing up the competition with a soccer mum car
          AWD removal sounds much easier than i had anticipated.
          • I was really impressed with your Tig mate for sure, not to be snuffed at, not sure if you saw the scary moment i had with it lining it up and the rollers, it decided to have a big walk, scared the pants off me!!! anyway tried again in reverse and it lined up nicely.
            Even with the dyno reading low was a top result mate.
            Jmac
            Alba European
            • TDI Tiguans ...... APR now has a Carbonio intake available in the USA. Speak to Guy and he'll likely be able to get you 1 in ....
              APR Transverse 2.0 TDI Carbon Fiber Cold Air Intake System
              • TSI Tiguan's - Black Forest vent mounted boost guage's are now available to match the White interior lighting 2009 ->
                VWVortex.com - BFI - Newsouth Tiguan Boost Gauge/Vent Pod *Exclusive*
                Looks pretty swish.
                Bit pricey though.
                • To revive an older thread...
                  Has anyone heard of the brand "custom code" chipping / reflash????
                  I have posted a new thread entitled the above too....
                  2018 Ralyee Green RS wagon. Fully optioned.
                  Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
                  2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
                  • OK here's the challenge. Mate's M3 arrives end of March (probably bit later). So I've got a few months to get the Tig to M3 specs. Shouldn't be too hard - here's the comparsion:
                    M3: 309kw, 400Nm, weighs: 1600kg
                    Tig - Stg1: 190kw, 403Nm, weighs: 1610kg
                    He's getting a manual, so no problems trying to compete with launch control crap.
                    All I've got to find is around 120kW, with a bit more torque (that should be easy) and I'll have him on toast I reckon! Should be easy. Guy?
                    • no problem:
                      • Originally posted by Guy_H View Post
                        no problem:
                        haha, just what I was thinking Guy - but will my clutch last?
                        • very funny....errr......how much!
                          by the way I've always wondered - can anyone tell me exactly what nitrous does, its already oxidized isn't it (nitrous oxide), so does it help create a denser air/fuel mixture?
                          Tiguan TSI Catalina blue, Manual
                          • Originally posted by jimbomort View Post
                            When you heat nitrous oxide to about 300 degrees C, it splits into oxygen and nitrogen. So the injection of nitrous oxide into an engine means that more oxygen is available during combustion. Because you have more oxygen, you can also inject more fuel therefore produces more power. Nitrous oxide has another effect that improves performance even more. When it vaporizes, nitrous oxide provides a significant cooling effect on the intake air. When you reduce the intake air temperature, you increase the air's density, and this provides even more oxygen inside the cylinder.
                            • Probably one of the best explanations:
                              Nitrous oxide engine - Wikipedia, the free encyclopedia
                                Quote: For example, in New South Wales, Australia, the Roads and Traffic Authority Code of Practice for Light Vehicle Modifications (in use since 1994) states in clause 3.1.5.7.3 that The use or fitment of nitrous oxide injection systems is not permitted
                                Damn!! That means I'm out... unless of course Guy you can fit these in 'Stealth Mode'
                                2011 Tiguan | 125TSI (5N) | Deep Black | DSG (7-speed) | Launch Control | 4Mo | Fog | Comfort | Bluetooth | MDI (USB + iPod) | Roof Bars | Rear Sensors | Floor Mats | First Aid Kit
