Intake Manifold Flap Position Sensor Error
  • Intake Manifold Flap Position Sensor Error
    Scanned a friend's 155TSI Tig that had the Check Engine Light on.
    Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
    Part No SW: 06J 906 027 BT HW: 06J 907 309 A
    Component: MED17.5.2 04 2133
    Revision: P3H07--- Serial number:
    Coding: 0423000C240F0160
    Shop #: WSC 01357 011 00200
    VCID: 7EA5ED239CFD160A5DF-802A
    VINID: 9E65EAAAA15EA969C004520124F3FD445D
    1 Fault Found:
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 - 000 - Implausible Signal - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 0
    Fault Frequency: 152
    Reset counter: 255
    Mileage: 73037 km
    Time Indication: 0
    Date: 2018.03.16
    Time: 02:53:36
    Freeze Frame:
    RPM: 1784 /min
    Load: 72.9 %
    Speed: 60.0 km/h
    Temperature: 91.0°C
    Temperature: 43.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.589 V
    Is this as simple as replacing the sensor as a starting point?
    Car Engine Air Intake Manifold Runner Control Sensor For VW Audi Seat 07L907386A | eBay
    Pull the sensor out but leave it connected to the wiring; read the advanced measuring values for the position sensor and see if the value changes when you rotate it.
    You are likely correct about it being a bad sensor, but it might be a stuck intake runner.
      1 Fault Found:
      Freeze Frame:
      Fault Priority: 0
      Reset counter: 255
      Mileage: 73037 km
      Time Indication: 0
      Date: 2018.03.16
      Time: 02:53:36
      Freeze Frame:
      RPM: 1784 /min
      Load: 72.9 %
      Speed: 60.0 km/h
      Temperature: 91.0°C
      Temperature: 43.0°C
      Voltage: 13.589 V
      Maybe, but maybe not.
      I had the P2015 error on my 2014 Eos, CCZB 155KW engine and had to replace the manifold. This is a known issue and there's a revised manifold available. Mine had the original version which was replaced with the newer version.
      I'm not sure how you tell the difference between the two or how one determines if the manifold needs replacement.
      14 EOS 2.0 TSI has arrived!
        Same issue with my Tiguan in October
        The intake flap actuator failed internally
        I supplied the new part
        06J133201BH - Variable Intake Manifold - Volkswagen Golf MK6 GTI, Tigu– VAGPARTS Australia
        Ultra Tune Garbutt ( Townsville ) did the work and also had to change over one of the old sensors to clear a new fault with the new intake.
        if you look at the intake flap actuator you can see the difference between the old & new
        Shaun
        2015 Tiguan 132Kw 4Motion
          Thanks All
          At $28, we will try the sensor 1st. If that does not fix it, it is likely the actuator has failed.
          VAGPARTS not the cheapest on that new intake (or any part really), I will start researching where to get a new intake from.
            Thanks All
            You can likely get it cheaper from USA or Europe, but obviously you will have to wait a few weeks for it to get here. VAGParts isnt the cheapest, but they are good to deal with, ship quickly and have the part in stock. Also you can use the code 5 for 5% off.
            Audi VW 2.0T Intake Manifold - Vaico 06J133201BH | FCP Euro
            403 Forbidden
            B9 Audi SQ5
              403 Forbidden
              How good is FCP Euro!
              I have bought quite a bit of stuff from them now and they ship quickly.
