Tiguan 2.0 TDI Intake Manifold Replacement still leads to a P2015 manifold error
  • Tiguan 2.0 TDI Intake Manifold Replacement still leads to a P2015 manifold error
    Hello.
    The car I have bought recently with 230 000 km under the belt seems to have a lot of issues with the infamous P2015 error code. I also had an issue with the EGR Valve which i replaced and didn't get any more codes regarding that.
    I ordered a new intake manifold and replaced the old one and I hoped that the issue would be gone, but however, after a shorter ride with the car today, I still get the p2015 error code, together with a check engine light in the panel.
    Running out of ideas and money for this car. Any ideas what the issue might be?
    From what I can read, I need to do adapt the new flap motor / intake manifold with the car. Does anyone know if this is possible to do with obdeleven or do I have to buy proper VCDS tool? How would you do the adapting with VCDS?
      VCDS can lead you through the process, assuming there is one. Usually you press a button and it does it itself. Bound to be a how to on tdiclub or youtube
