Reverse tail lights
  • Reverse tail lights
    Just purchased a new 132tsi comfortline. I noticed that when I put it in reverse there is only one reverse light illuminated. Not sure if the other bulb is busted or whether there is simply 1 reverse light. I had read on a European forum that this is the case but wanted to double check.
    Standard on many European cars. The other light (which is basically useless in Aust) is a fog light.
    2015 Audi SQ5 - SOLD
    New car incoming...
      There will be only one reverse light.
      '07 Transporter 1.9 TDI
      '01 Beetle 2.0
        Can you use a VCDS to program the rear fog light to come on when you engage reverse gear?
        Sent from my SM-G930F using Tapatalk
        Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
          I don't think so but feel free to try. I ended up buying another genuine taillight for the US market from o'seas with a second reverse light and hooking it up in my Golf.
          New car incoming...
            Delewin: My apology to Lucus_R, but yes- it's indeed possible to make the rear fog light operate as a reverse light.
            There's many ways to do this with Leuchte programming, but perhaps the easiest is as follows:
            1. Select 09 - Central Electr control module
            2. Select Security Access - 16 from the "Open Controller" screen
            3. Enter the magic number 31347 and return to the "Open Controller" screen
            4. Select Adaptation - 10 from the the "Open Controller" screen
            5. Enter LA72 into the search box and from the pull-down arrow, select ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26
            6. The default value of this channel should be not active - only if this is so, change the setting to Rückfahrlicht
            7. Click the Doit! button to accept the change
            This process automatically applies the same illumination level to the reverse light that is factory set for the fog light function (which will be 127 since the new Tiggy has LED tails)
            Don
            PS: I don't own the new Tiggy (I have a Golf mk7), but I have found that it's also useful to turn-on the 3rd Brake light when reversing. It's unfortunately a red color, but the higher position of the LED strip seems to provide a good general illumination when going backwards!
            If you also want to apply this function to the 3rd Brake light - see my instruction HERE. Note: use the instructions for the last column of the table, but don't apply the changes in column 1, or 2 to the Tiggy (the 3rd Brake light on the Golf mk7 is factory programmed differently to your beast)
              Many thanks DV52. I'm still snowed over with work so my to do list is growing.
                There are 2 functioning reverse lights on the 162Tsi
                  Yes. I can confirm there are 2 functioning reverse lights on my 162 TSI.
                    Hi Don, just wondering ... so the 3rd rear light is on a lower setting with the reversing lights on and then increases to the normal brightness when the brakes are activated?
                    Current:
                    2017 Mk2 Tiguan 162TSI, R-line, White
                    2020 Mk7.5 Golf R Wagon, White
                      veew: You always ask interesting questions!
                      If you look at the table in my link, you will notice that the brake light function and the reverse light function both have the same Dimmwert value (i.e. 127). So both activities are equally illuminated!
                      Also, I have designed the tweak so that the reversing light has the highest priority, but in truth when both the bake light and reversing light are on together, the effect appears to be the same. But how often is the car reversing on a major highway?
                      Don
                        Any tiguan owners done this tweak?
                        Bump... just want to see if anyone with a Tiguan has done this with OBD11 yet?
                        I hate the 1 reverse light on my Allspace. I have to constantly tap the brake light when i reverse at night to see adequately.
                        Cheers.
                          Anyone done this on the Tiguan Allspace?
                          Cheers.
                          Bump, would also like to know, as i've recently just purchased a 2022 Tiguan Allspace, and the one reverse light is triggering me Already disappointed that my dealer told me even if i sourced the LED tail lights and install myself, it would void the warranty.
                            Why dont you just put your left foot lightly on the brake pedal and have all your rear lights on. Been doing that for 50 years long before reversing lights were invented Works perfectly
