Originally posted by Dose Pipe Sutututu
View Post
Mk2 Tiguan Tuning
Originally posted by INASNT View PostKeep a spare ecu with stock tune and swap out when needed.
Originally posted by Dose Pipe Sutututu View PostYep I caved and got the wife's Tiguan flashed at German Performance Garage for $1100 during the sale...........
...........Next and hopefully last mod is to fit a larger FMIC.
And that's it, no more mods.. LOL
Sent from my iPhone using Tapatalk2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
Originally posted by Dose Pipe Sutututu View PostYep I caved and got the wife's Tiguan flashed at German Performance Garage for $1100 during the sale, prior to that I installed both the Racingline Turbo Muffler Delete and Turbo Inlet.
One thing I did notice with the Tiguan is the paper thin FMIC, with the APR Stage 1 tune it's now seeing boost peak at 1.5bar and tapering down to 1.4bar (turbo compressor efficiency full hitting a brick wall hence boost drop) which does make it feel very "urgent" to move - however, with the boost comes heat soak. After a few fun squirts you can really feel the heat soak, which I assume the ECU's strategy is to trim ignition timing vs. intake air temperature.
And that's it, no more mods.. LOLTiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
Originally posted by REXman View PostJust order the turbo already!
Originally posted by INASNT View PostI want to see a full engine rebuild pumping out atleast 700hp from you mate on the Tiguan.Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
This has been done to death but found some interesting power bump data from APR in regards to using 98 RON over 95 RON.
APR 2.0 TSI/TFSI Gen3 ECU Upgrade for the MQB Platform
Not sure if I'm reading it right but they seem to say for the stock 220 PS Model (I'm assuming this is the 162TSI) gets a 20kw and 25NM increase in power, just by using 98?
Obviously it's not using the same testing criteria but seems like a good increase if true.
VW may also be downplaying power stated.
2019 VW Tiguan 162TSI R-Line + Sound & Vision Package - Tint - Roof Bars.
2019 Mazda CX9 - Tint - Roof Racks.
Thanks INASNT for the reply.
So, the stock Tiguan 162TSI actually pumps out 182kw and 375nm on 98 RON and 162kw and 350nm on 95 RON?
Just interested as my 2019 Mazda CX9 gets an extra 16kw for using 98 RON. Goes from 170kw to 186kw, although there's supposedly no change in nm though.Last edited by digger; 18-02-2020, 02:25 PM.
It does seem high, although you seem to be able to get a lot from this engine with minor mods.
I just calculated the kw and nm from the APR data calibrations, in my original post.
Originally posted by PDMJO View PostI’d be inclined to assume with 98 the max output is 162kw, rather than 162kw being the minimum. Just going based off drivetrain loss, 182kw seems too generous.
Also 0-100 times tend to confirm that to be the case also. So I really don't trust VW's brochure 162kW figure but I have confirmed the claimed stock 0-100 for the 162TSI is pretty spot on at 6.5sec. Which doesn't stack up given that the last of the gen1's with 155kW was 7.3sec. So how can you run almost a full second quicker 0-100 with only 7 more kW?
All things point to 182kw as stock output for the 162TSI Tig. My 162TSI was running at 137kwaw on the dyno and if you factor in around 25% driveline losses for the AWD and DQ500 then the numbers all line up.
