Originally posted by veew
View Post
Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
Originally posted by veew View PostJust interested in knowing a few things about your vehicle.
What are the specs of your vehicle? Trim level and model year?
What towbar do you have? VW Genuine or Westfalia or other?
Originally posted by Jap View Posti have a 2017 facelift golf with trailer assist factory fitted, if that's any help (I can look at the codings Monday (uk time) if that's any help)
Please could you post your codings & adaptation channels so I can compare. I followed these instructions on my MY17 Tiguan R-Line:
Activate Trailer Assist - VCDSSchweiz
I had the genuine trailer electrics installed by dealer, so car knows when trailer plugged in, but Trailer Assist never worked. After altering the above coding & adaptations, I now get a message that Trailer Assist is available and to press the Park Assist button when the car is in reverse - once I do that, a picture flashes up showing how to control via the side mirror selector/adjuster, but then an error message comes up to say take control of the steering wheel as Trailer Assist is not available due to the reversing camera being obscured.
I have no idea why this error occurs, as the camera is clean, I have removed the jockey wheel & re-routed the trailer plug out of view in-case it is getting confused.
I did have a problem with the final adaptation change, as Klemme 15 does not appear in the drop down list??
Any assistance would be greatly appreciated.
Backup
Control unit: 69 Trailer Function
System description: Anhaenger
Software number: 5Q0907383H
Software version: 0204
Hardware number: 5Q0907383C
Hardware version: H21
Serial number: 0428187970
ODX name: EV_TrailFunctGener2Hella
ODX version: 001008
Backup name: trail
Long coding:
0100000202000000
Adaptations:
Production mode:
Activate start-up mode:
not active
Control module switch-off, counter:
Control module:
0 min
Data bus:
0 min
Control module switch-off, switch-off time:
Control module:
30 min
Data bus:
15 min
Backup
Control unit: 6C Camera System Rear View
System description: RVC Compact+
Software number: 5Q0980568A
Software version: 0180
Hardware number: 5Q0980568A
Hardware version: H07
ODX name: EV_CamSysRVRVCARPANAMQBAB
ODX version: 006008
Backup name: rear cam
Long coding:
0173000161002001000048
Adaptations:
Activating and deactivating all development messages:
Not activated
Actuator, PWM signal:
100 %
Brightness:
50 %
Control module:
20 min
Data bus:
30 min
Image contrast:
50 %
Wheel/tire description:
1950 mm
camera_off:
35.00 km/h
camera_on:
30.00 km/h
color:
50 %
debounce_time_for_reverse_gear:
0 ms
display_position:
0 px
engine_restart_timer:
0 ms
Frequency_Swinging_Logo:
100 Hz
FSG_control_state:
On
grafic_element_setting:
setting_1_HMI_mode:
ff
setting_1_pallet_ID:
255
setting_1_color_value:
ffff
setting_2_HMI_mode:
ff
setting_2_pallet_ID:
255
setting_2_color_value:
ffff
setting_3_HMI_mode:
ff
setting_3_pallet_ID:
255
setting_3_color_value:
ffff
setting_4_HMI_mode:
ff
setting_4_pallet_ID:
255
setting_4_color_value:
ffff
setting_5_HMI_mode:
ff
setting_5_pallet_ID:
255
setting_5_color_value:
ffff
setting_6_HMI_mode:
ff
setting_6_pallet_ID:
255
setting_6_color_value:
ffff
setting_7_HMI_mode:
ff
setting_7_pallet_ID:
255
setting_7_color_value:
ffff
setting_8_HMI_mode:
ff
setting_8_pallet_ID:
255
setting_8_color_value:
ffff
setting_9_HMI_mode:
ff
setting_9_pallet_ID:
255
setting_9_color_value:
ffff
setting_10_HMI_mode:
ff
setting_10_pallet_ID:
255
setting_10_color_value:
ffff
setting_11_HMI_mode:
ff
setting_11_pallet_ID:
255
setting_11_color_value:
ffff
setting_12_HMI_mode:
ff
setting_12_pallet_ID:
255
setting_12_color_value:
ffff
setting_13_HMI_mode:
ff
setting_13_pallet_ID:
255
setting_13_color_value:
ffff
setting_14_HMI_mode:
ff
setting_14_pallet_ID:
255
setting_14_color_value:
ffff
setting_15_HMI_mode:
ff
setting_15_pallet_ID:
255
setting_15_color_value:
ffff
setting_16_HMI_mode:
ff
setting_16_pallet_ID:
255
setting_16_color_value:
ffff
setting_17_HMI_mode:
ff
setting_17_pallet_ID:
255
setting_17_color_value:
ffff
setting_18_HMI_mode:
ff
setting_18_pallet_ID:
255
setting_18_color_value:
ffff
setting_19_HMI_mode:
ff
setting_19_pallet_ID:
255
setting_19_color_value:
fff
image_delay_timer:
0.0 s
Minimal_time_to_stay_in_bus_sleep_before_ECU_off:
20000 ms
rv_dark_off:
10.00 km/h
rv_dark_on:
15.00 km/h
RV_Last_Mode:
90° parking spot
RV_Start_Mode:
90° parking spot
Time_to_open_Swinging_Logo:
1200 ms
I installed speed sign recognition on my Tig. Worked fine for 2 weeks but now getting an error message "traffic sign recognition fault" and a non- erasable fault (U1120) in the dashboard module on my OBD11. Has anyone else experienced this? It still seems to work according to my wife, but have not checked it myself yet.
Tomorrow evening I will dump my Tiguan and investigate the TJA further. Also will do some changes together with a friend who has VCDS/VCP etc.
Like Video-in-motion, DRL's at the back, disable warnings on the Navi, beep at lock/unlock, needle sweep, when using auto climate control see the speed indication stuff like that.
We will also try to investigate and compare dumps to get a hold on the TJA thing. He thinks more coding needs to be done besides the modules13 and 44.
Originally posted by NZ_GolfR View PostHere is the coding to enable Rear DRL. This works on the LED Lights that come with the NZ R-Lines, not sure if it works with any other type of rear lights.
Central Electronic (09) - Adaptation - Leuchte16BLK SLB35BLK SL KC9 - Lichtfunktion B 16 - Change to Tagfahrlicht (Original Value: Parklicht rechts)
Central Electronic (09) - Adaptation - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3 - Lichtfunktion B 17 - Change to Tagfahrlicht (Original Value: Parklicht links (beidseitiges Parklicht aktiviert li & re))
Central Electronic (09) - Adaptation - Leuchte23SL HLC10 - Lichtfunktion B 23 - Change to Tagfahrlicht (Original Value: Parklicht links (beidseitiges Parklicht aktiviert li & re))
Central Electronic (09) - Adaptation - Leuchte24SL HRA65 - Lichtfunktion B 24 - Change to Tagfahrlicht (Original Value: Parklicht rechts)
There is option in there to adjust the brightness as well however I haven't changed this setting as it will potentially make the park lights too bright at night time.Current:
2017 Mk2 Tiguan 162TSI, R-line, White
2020 Mk7.5 Golf R Wagon, White
Just wanted to thank everyone who has contributed to this thread. I've activated the following thanks to many of you:
- 3rd/High-Mounted Brake Light Tweaks
- Avoid Dimming LED Lights when Indicating Golf Mk7
- Traffic sign recognition/Dynamic Road Sign Display
- Automatic Window Closing in Rain
- Enable rear DRLs
- Adjusting Cornering Fog Light Sensitivity (Speed Threshold)
- Disable Start/Stop
- TMC Traffic
- Seat heating memory
- Enable Fan Speed Indication for Airconditioning when in AUTO mode
- Gauge/Needle sweep on AID
- AID GTI/R adaptations
- AID Colour change
- Disabling screen Nag
- LED lights in door mirrors light, even in close
- Lock Acknowledge with Horn Golf Mk7 instructions
- Automatic Air Recirculation
Current:
Originally posted by veew View PostJust wanted to thank everyone who has contributed to this thread.
It seems your first post is fairly up-to-date with links - perhaps the mods can make this post 'sticky'?Last edited by spacemannz; 02-10-2017, 09:12 PM.Tiguan Highline 162TSI | Indium Grey | DAP | MY18
Just a thought - the US-spec Mk2 Tiguan remote start via the keyfob - is it possible that in *theory* this is just coded into the car with no additional hardware as it starts the engine when triple pressing the unlock button? if so it may be able to be coded in to a ROW spec Tiguan? and thus coded to my Golf 7.52018 Golf 7.5 110TSi Comfortline | Drivers Assistance Package | Retrofitted: Traffic Jam Assist | Emergency Assist II | Light Assist | OEM Vienna Leather Sports Seats with full Highline Interior | Power Folding Mirrors
