Hi all,
Started getting this snapping sound coming from the Tig. After it first happened, it happened a few times until I got home (3 minute drive). Then I took it out for a drive to check and it happened quite frequently when both turning and going straight. Sounds like something getting into tension and the suddenly releasing. When it first happened, it made quite a large knock sound. I recorded the audio when I took it for a check, it happened a quite a few times, but can be clearly heard at 00:40, 01:54, 02:02, happens more towards the end as well but its the same sound as the earlier ones.
SndUp | Post info
Want to get some ideas before taking it to a mechanic.
Thanks in advance.
SndUp | Post info
Thanks in advance.
