Wiper blades - 2017 Tig
  • #16
    Originally posted by SDST View Post
    Anyone else notice the wipertech front blades are about 1 inch longer on the driver side, a little longer on the passenger side, but about 1cm shorter on the back?
    Any idea where the extra length will put extra strain on the wiper motors and cause a failure eventually?
    I just got my Wipertech blades for my Tiguan and noticed exactly the same thing!
    Did you end up installing yours in the end? If so any issues with operation?
    My friend said one of his Bosch Tiguan wipers was a bit longer and would hit the windscreen frame when it was on the fastest setting.
    I've put my Wipertech wipers back in the box for now and will see what Wipertech say before making a final decision.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
    • #17
      Never noticed that - sorry. I have Wipertech's on both my cars currently (as well as several previous cars) and never had any issues with them.
      As long as the wipers dont contact each other and dont hit protrude past the windscreen glass then I dont see the issue.
      B9 Audi SQ5
      • #18
        I got some Wipertech for my Tig last month (at less than 6 months old) - the factory blades were shuddering and squawking despite my best efforts to clean the screen and blades and graphite treat the rubber, nothing seemed to shut them up for long.
        Seem poor quality.
        The OEM set on my Golf R were easily better and lasted 3 years with normal use and normal maintainence!
        The Wipertech were a little longer at front but no issues striking anything. Didn’t get a back one.
        • #19
          Seem poor quality.
          But......are they an improvement over the factory fitted VW wipers? I can only assume so, as the factory ones VW use are garbage.
          Also as an ongoing discount code, use REDRIVEN15 for 15% off Wipertech blades.
          B9 Audi SQ5
          • #20
            I loved your OEM blades on my GTI and only recently changed them after four years for a wipertech set, which seen good.
            I kept the original blades just in case I study like them and could put them back if needed for a bit. I got the back one too.
            Length seemed perfect sheet I got a set for the Polo which I realised uses the same size.
            Bear in mind that you need to keep your windscreen clean for best performance.
            MY20 MK7.5 Golf GTI - Tornado Red - LP/S&SP
            MY19 AW Polo - Comfortline - DAP
