High pressure washer
  • High pressure washer
    Just wondering if it’d be safe to use a 1740psi high pressure washer on our Tiguan due to sensors etc. I also hear that it can damage rubber seals etc if not angled right. I normally use a garden hose with 2 bucket method.
    MY20 Tiguan Allspace Black - R-Line, S&V, Pano roof
    MY11 MK6 GTI Black - Leather, Sunroof etc.
    MY17 MK7 Golf 92 TSI
    MY18 Mazda CX-9 Touring AWD (For sale)
    I use my washer. It has a similar psi rating.
    It isn’t strong enough in my opinion. Only gets off the same dust that a garden hose does.
    Anything like bugs, bird poo and road grime still needs sponging.
    Disappointed in mine and it wasn’t a cheapie
      Yeah, I’ve heard of some complaints about high end Karcher ones not as strong as the cheaper models. I’m getting a Bosch one through Flybuys rewards but just wondered how safe it is to use on new cars with sensors. It might end up cleaning my driveway etc if not safe.
        I've got a Bosch Aquatak back from when the state gov were giving out rebates for purchasing pressure washers.
        It's 1300W and makes short work of droppings & bugs. No issues with my sensors, and I put the gun right up to the panels.
          My 2100psi Gerni was written off in floods recently, and I just replaced it with a 1900psi Karcher K4. No problems at all using it on many cars over the years - just dont get any closer that about 30cm otherwise you do risk possibly peeling paint off.
          Both the Gerni and Karcher were approx $450-500 so not cheap ones.
          The Karcher is noticeably less powerful than the Gerni was.
            I was watching a Youtube video from Dallas Car Care or something like that, and the guy there said that he wouldn't use a pressure washer stronger than 1200 PSI. He reckons buy a cheapie and it's good enough for most things, and won't damage your paint. Cheers-John
              Depends on the lance you use, just don’t use dirt blaster on the car
              2018 BMW 125i M Sport |AlpineWhite|719M JetBlack|BlackLeather |ComfortPackage|Sunroof|WirelessCharging
              2010 MY10 R36 Wagon | Biscay Blue | Power Tailgate | RNS510 | MDI | RVC | 51,000 km |Garage Open Button | Dead Pedal Mod | OE Fit DRL | VCDS | Sprint Booster | H&R Rear Sway Bar | Alcantara Steering Wheel | Dual Reverse Light | 19" Bentley Wheels (BBS Forged Split) | Michelin PS 4S
              2005 MY05 AH Astra HatchBlack | Facelifted SRi Looking | OpeliZed | Whiteline RSB | Eibach ProKit
                Mine might be an older model as well. It’s Aquatak 120 1500W I think. Good to know that there is no issues with sensors.
                  Definitely not cheap those ones. Thanks for the heads up. I’m just amazed that it could even peel the paint off from that distance. Better not go too close to window frames etc I guess. I just wonder if it’d even be worse on the older paint with stone chips etc.
                    Originally posted by southtig
                    The tig is so small compared to full size 4wds that I'm faster with a hose and bucket than it takes me to set up my karcher. The modern shaggy cloths instead of sponges and a couple of big micros instead of chamois help massively. Karcher still is boss on 4wd/boat/concrete/decking duties.
                    This Bosch unit seems to be quite easy to assemble but I see what you mean. Anyway will see.
                      Thanks for that tip. So I guess just use it with the wider spread from some distance away.
                        Mine's the Aquatak 10 if the additional info is of any use to you. Had to go out to confirm.
                          Mines the aquaTak 130, 1885psi.
                            Thanks for that again, 👍 it looks like it’s a 1450psi unit.
                              Thanks for that. So mine’s in between yours and PDMJO’s in terms of psi. Will see how it works on new and old cars.
