MY23 T-ROC Trip Meter missing?
  • MY23 T-ROC Trip Meter missing?
    Hi Folks, I'm kinda embarrassed I didn't notice this earlier. The T-ROC I bought for the missus doesn't seem to have a trip meter that you can reset? I get it that it tracks distance travelled/duration per drive but what I am looking for is the trip meter which doesn't reset after every drive. I'd really like to calculate how far I can go for every full tank of petrol.
    I checked all the settings and the UI doesn't have any settings to enable it. My Golf has a physical button in front of the dashboard to reset the trip meter but the T-ROC does not.
    The T-ROC is a MY23 Style with the only additional option being the electric tailgate.
    MY20 MK7.5 GTI - Solid White
    MY23 T-ROC STYLE - Silver Metallic
    So take the kms on odo when you fill up and again when you refill Same S++t different bucket Sheesh
      What a totally useless comment ...
        You should be able to use the button on the steering wheel to reset it. In the driving data menu on the digital dash, scroll down using the buttons on the righthand side of the steering wheel until you get to the trip item, and then press and hold the OK (or equivalent) button to reset the trip meter.
        It caught me out too on our T-Roc R (and my daughters T-Roc Style).
        BTW: How good a car is that T-Roc Style!!!! OK engine, really nice gearbox, decent interior space. Best value VW on the market IMO.
          what he said
            I reckon the bad mood fairies have been visiting him again. Seems to go through phases...
              Thanks Sharkie. With this, where does the trip info appear on the dashboard? I'll try to capture a few photos tonight if I can't get it resolved. The only distance indicator I have on the dash is the odometer.
              Yes, love the car. I'm actually quite surprised by the punch it has. Interior especially the door frames seem a lot more solid when compared to my Golf. My door creaks when I lean my elbow on the frame when I drive lol
                Not at all but whats the difference taking readings off the running total on the ODO to as he says the running total on a trip meter as my trip meter just keeps on after every trip It doesnt go back to zero when restarting the car as I used to annoy myself when wanting to do the same and always forgot to reset it
                  Its a feature that every car should have and it should be very easy to use. Yes of course you could use a pen and paper (or use your phone to take a photo) of the odometer to do what you say - but frankly that seems quite ridiculous when this feature should be easily accessible and easy to use. I use it on my cars all the time to keep a general eye on fuel consumption so that I can hopefully notice if something starts playing up and fuel consumption increases noticeably....something that would be harder to do without a tripmeter.
                  Other people may use it to calculate how far they drive in a day or week, or how far it is to drive to a friends house that is some distance away etc etc.
                  B9 Audi SQ5
                    ^This. It is a standard feature on all the cars I have driven in my decades of driving. The problem is I cannot find a way to turn it ON. It has the Odometer that tracks the lifetime distance the car has travelled but I cannot for the life of me find the option to turn on the trip meter let alone a 'reset' button for it.
                    The Dashboard does have a distance travelled and 'total travel time' metric that resets itself every time you turn off the ignition.
                    @Hillbilly -I understand your point about the pen and paper and what not but the fact of the matter is, it is usually a standard feature and people take it for granted that it is there. I paid a lot more for this car than my 2010 corolla and it has it. I can't for the life of me find this feature on a 2023 modern VW. Will check back with photos when I can.
                      Well have just been out to my Kamiq which is a T Cross in a different dress
                      The trip is displayed just inside left dial at the bottom and in the right side is either the odo reading or if you have ACC enabled it shows that . To reset the trip meter it as said above needs to be scrolled down in ASSIST systems and then press the roller till it zeros. Presume yours has the same wheel as mine and in a Kamiq Manual its on page 52 and the section is Driver Information systems . Gives 2 options using either buttons on the right hand wand or as above. mY trip meter just keeps on adding up nad needs a manual reset to go back to zero.
                      I used to write down all the figures when it was new but now if it needs a drink it gets one and to hell with it. There is also a screen comes up and tells you all that info if you turn it off and dont open the door.
                        Heres how to do it in the KAMIQ would think a ROC will be the same Go to menu Vehicle status/settings/ vehicle settings/ instrument cluster settings Scroll down to reset trip meter press reset and its done Mine now shows 0.0
                        EDIT I have an Amunsden MMI so not sure what you have but menus will be similar
                          The quickest way of doing this without going to the radio screen is as follows:
                          My digital dash is setup like this normally with a digital speedo in the centre (which means I have the driving data set selected)
                          Change the display option (in that center bit of the screen) with the up/down arrow and OK buttons.
                          Note that the L/R buttons will change the central section to a different set like Navigation for instance.
                          With the up/down arrows move through the options to get to trip setting.
                          Start here (in my case)
                          Go to here
                          press OK and it will reset the trip readout on the dash.
                          Takes all of 10s.
                            Thanks guys. My dashboard looks different to the ones posted here. Mine looks 'simplistic' in comparison.
                            Here's a screenshot of the dashboard: Imgur: The magic of the Internet
                            Here's a video I captured while looking at the settings. MY23 T-ROC - No trip meter setting - YouTube
                            I am convinced I don't have this option on my car
                              That is just a different configuration of the display on the screen. The digital dash is VERY configurable. I could have a similar set-up if I so choose, which I don't
                              I'd suggest you pull out the owner's manual and have a read on how to change the display.
                              I could be wrong, and that may be a more basic dash version, but the owner's manual should still tell you.
