Amarok V6 Check Engine Issues
  • Amarok V6 Check Engine Issues
    I have a V6 Amarok with a recurring but intermittent check engine light.
    I have scanned the error codes and get two different codes depending on which tool I use.
    Using OBD11 I get an error code 0538 and under voltage issues with various exhaust gas temp sensors etc as well as a Central Electronics error of open circuit.
    Using Carly I get an 021A message which seems to indicate an injector issue (but is probably triggered by the under voltage errors as per OBD11 above).
    I have checked every fuse that I think may be at fault and found nothing. Checked the battery and charging rate and all seems fine in that area. I'm not sure where else to start looking.
    Has anyone else had this issue and if so, what is the cause.
    Thanks in advance if anyone can offer suggestions or solutions.
    Darryl
    If you can upload the error log from OBD11, it will help pinpoint the issue.
    Use the app's email function, to send it to yourself, then you can upload it here.
    00538 - Reference Voltage : Signal too small, is a general error that could be triggered on many modules.
      Here are the two fault logs;
      OBDeleven vehicle history log
      Date: 2023-08-17 19:03:16
      VIN: WV1ZZZ2HZHH014936
      Car: VW Amarok V6
      Year: 2017
      Body type: UNKNOWN
      Engine: DDXC kW ( hp) l
      Mileage: 175190 km
      01 Engine
      System description: 3.0l V6 TDI
      Software number: 2H6907311E
      Software version: 0001
      Hardware number: 059907309J
      Hardware version: X21
      Faults:
      P220100 - NOx Sensor Circuit Range/Performance Bank 1 Sensor 1
      static
      Priority - 2
      Malfunction frequency counter - 1
      Unlearning counter - 255
      km-Mileage - 175062 km
      Engine speed - 1832.00 1/min
      Normed load value - 39.6 %
      Vehicle speed - 103 km/h
      Coolant temperature - 95 °C
      Intake air temperature - 22 °C
      Ambient air pressure - 1010 mbar
      Voltage terminal 30 - 12.760 V
      Dynamic environmental data - 20962810261A85150D008C150E009515260287132F20001139 060816250B41
      date - 2072-12-23 09:14:02
      static
      Priority - 2
      P103300 - NOX Sensor
      Signal too low
      static
      Priority - 2
      km-Mileage - 175056 km
      Engine speed - 1364.00 1/min
      Normed load value - 60.0 %
      Vehicle speed - 75 km/h
      Coolant temperature - 91 °C
      Intake air temperature - 19 °C
      Voltage terminal 30 - 13.060 V
      Dynamic environmental data - 20962810261752150D0092150E008D152604D6132F1FFE1139 08E716250B3C
      date - 2072-12-23 09:10:41
      2nd Fault Log for code 0538
      Date: 2023-08-17 19:04:01
      Car: VW Amarok V6
      Year: 2017
      Body type: UNKNOWN
      Mileage: 175190 km
      09 Central Electrics
      System description: BCM PQ25 MMI4
      Software number: 7E0937089A
      Software version: 0744
      Hardware number: 7E0937089
      Hardware version: H81
      Faults:
      00538 - Reference voltage
      static
      priority - 3
      frequencyCounter - 2
      drivingCycle - 77
      km-Mileage - 175045 km
      Not sure where to go from here to sort the issue. Any help would be appreciated.
        Best shift this to the AMAROK forum This is the RULES forum as its labelled
          Thread moved to Amarok section. Sounds like you have a failed NOX sensor. Not entirely uncommon. Genuine VW NoX Sensor for Volkswagen Amarok 3.0 TDI Engines
