I don't believe so but could not be sure...... need accesss to ETKA to check but I don't have it .... I managed to find someone on ebay that had these for sale for 100 delivered for both controllers. Waiting for those to arrive.
1 of 2
2 of 2
Fitting Folding Mirrors to the Mk7 Golf
I have done this on 7R, don't need controllers or any wiring changes, just coding. Here are the part numbers.
Left Mirror 5G2 857 507 CA 9B9
Right Mirror 5G2 857 508 AJ 9B9
Switch 5G0 959 565 AA ICX
Unsure if GTI and lower require controllers, these are probably the correct ones. Unsure if wiring changes are required however i don't think they would be needed.
Drivers Door Controller 5Q0 959 593 B Z0G
Passenger Door Controller 5Q0 959 593 B Z0G
Hi,
Those are the Base Part numbers for all the controllers, what matters is the code after 593 B, 592 B.
For Folding you need Z0T version, non folding is Z0F. Now the problem was that I didn't see this actually printed on the controllers at all on the ones that came in my 7R so i don't know how to tell. at least in mk5 golf it wouldn't accept the +4096 required for coding however from research all controllers in 7R will accept mirror folding coding whether it supports the feature or not.
Originally posted by DV52 View PostPeekay: Arhh .. that's much better!! Thanks for sending the document. It seems from the wiring diagrams that I posted earlier that the critical connector on the door module for the fold-in facility is T16a I've decoded the German for the 16 Pin connector on your document. The results are enclosed below
From what I can tell, the door controller models "FA Max" and "BF Max" appear to have compatible pin assignments with my wiring diagram. This being the case, am I right in suggesting that the correct part numbers for the door modules for fold-in mirrors are:
Driver's Door :FA Max - 5Q0.959.593.B (this aligns with the part number on your pic above)
Passenger Door:BF Max - 5Q0.959.592.B
The part numbers for the door controllers on my car are:
Driver's Door :5Q4.959.593
Passenger Door: 5Q4.959.592
Can you advise if these are compatible with fold-in mirrors?
Hi I am pretty sure the part numbers are the same I ordered (don't have the paper work). The controllers are a back up only just in case. It is weird that VW don't label the controllers with the information above...but hope I have the correct ones. I should hope they arrive maybe next week as they had to come from Germany. The cost to buy them at trade was not much difference than that of oemvwshop but that site seems to have disappeared just checked again and is back...... I have the switch already in preparationLast edited by peekay34; 06-01-2015, 05:06 PM.
For Folding you need Z0T version, non folding is Z0F. Now the problem was that I didn't see this actually printed on the controllers at all on the ones that came in my 7R so i don't know how to tell. at least in mk5 golf it wouldn't accept the +4096 required for coding however from research all controllers in 7R will accept mirror folding coding whether it supports the feature or not.Please don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
Originally posted by peekay34 View PostMirrors now arrived as well....Please don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
Would love like DV52 the process, but also would like if possible to know where you got everything from and part numbers.
I think this is probably a mod that is far above my skill and expertise but would like to get all of the parts together to get someone with the skills to complete it of me.
Dawson2014|MK7|GTI|PureWhite|DSG|Bi-Xenon|Leather|Driver Assist|Tint
Well...... the mirrors I received were the wrong ones and will be returned back (damn vw dealer who gave me the incorrect numbers). fortunately the dealer will take them back as they are the standard mirrors. This will give you and idea how to fit..... http://www.uspmotorsports.com/downlo...structions.pdf btw I used these instructions.Last edited by peekay34; 16-01-2015, 11:46 PM.
Comparing the actual pins on the modules unfortunately isn't an indication as the connector look indentical. I didn't take a good look at them when the door card was off at the time.
Originally posted by DV52 View PostBooba: thanks for the additional piece of information. Regarding your dilemma about how to tell whether you have ZOT, or ZOF version modules, doesn't the pin-out give you an indication. For example, if you look at your current modules (notwithstanding that you don't currently have fold-in mirrors) and then see if any of the pins are populated according to my pin-pout diagram (which is really from peekay's document
Test Slow
