The Official Mk7 Wheel Thread
This is a sticky topic.
  • Originally posted by AdamD View Post
    These are a great rim, Mk6 or Mk7! (y)
    No disagreements here.
    As are CH-Rs (18 x 8.5, ET47):
    • VW MOTORSPORT - REVISITED
      Specs: 18 x 7.5, ET51, weight 23.1lbs/10.5kg
      • [QUOTE=Dutch77;1115178]These aren't a bad looking wheel, not sure exactly what they are although they are similar to Vossen CV3s. Obviously this is a stance fitment at 19 x 9.5, ET35 in conjunction with KW V1s:
        I'd go as far as to say they they are either a 10 or 10.5 width to get that amount of concave...
        • Originally posted by DUB32 View Post
          They definitely have a very concave look, although in this instance the owner/someone who knew the owner posted the actual specs as quoted with the pics at 9.5.
          • Going for the bumblebee look with Cadiz finished in a matte black:
            • Originally posted by Dutch77 View Post
              Can you kindly point me in the direction of said owner/someone knowing owner to confirm as I am interested in finding out more for my own car setup.
              Regards
                PM sent.
                Sounds interesting - I hope we get to see the final set-up?
                • Can you actually fit 10.5 wheels in a Golf R? Wow!
                  I was thinking of going for a 9.5. No stance just want wider tyres for grip.
                  • Originally posted by Mila View Post
                    I'm sure someone has, or someone will.. but you're talking about massive work to make that work.
                    Even at 9.5 you're unlikely to make that fit legally - that Golf R wasn't even close to being ok here.
                    If you're looking for grip, and not stance, than I am guessing performance is your main goal so I'd be looking at going light weight and something in 8 maybe 8.5 wide only. Obviously you'll save a bit by looking at 18 x 8 over 19s, but you're call on what will meet your needs. There's quite a few guys tracking on here so should be plenty of good advice in that regard floating around.
                    • hi
                      I've been reading almost the whole thread, yet, I am quite hesitant to buy and install some Audi S6 replicas, 18 x 8 ET 45, I think they could poke a bit inside the wheel arches, and according to Will They Fit, the wheels will poke more 2,5 cm to the outer part, compared to the 16 x 6,5 Dover originally fitted
                      so, my plan B is the Amarok "Durban" replica, curiously the name of those from Golf, but a different wheel, they're 18 x 7 ET 42 which will poke just 1,0 cm out
                      also their center bore is 57,1 fitting exactly, without center adapter rings
                      • Originally posted by RSW_BR View Post
                        hi
                        The 18 x 8 ET45 wheels should be perfectly fine on a Mk7 unless there is something different with your specs as I notice you are in Brazil.
                        I am running 18 x 8 ET48 right now and have plenty of room still - generally anything up to x 8.5 ET45 is considered ok on the Mk7 to sit on the wheel arch.
                        • VW ROTARY - REVISITED
                          Specs: 18 x 7.5, ET51, weight tbc
                          • VAG motorsports project Golf R
                            • Originally posted by sergioscirocco View Post
                              Still not a real fan of the Oettinger rear wing but the gloss black finishing around the car offset with the white does work in this instance.
                              I wonder if they've wrapped the rear valance to finish it in gloss or whether it's just the way the lights reflect. The mirror caps definitely need to be finished off in gloss black though IMO.
                              And more aggressive round pipes > oval.
                              • how do you print screen
