Ive Installed a Towbar on my 110TDI wagon. Its made by CTB at Botany NSW, only rated for 1000kg though.
I installed the Genuine Wiring harness & control unit
Wiring harness Kit PN 5G0055202, Though Wiring harness Kit PN 5G9055202 is meant to be used for the estate. doesn't matter to much
You also need the retainer for the control unit PN 5G6971502. this holds it on the LHS underneath the Jack Kit
Coding can be done using VCDS, though the Golf doesn't overly like it. You may need to initiate the CAN Gateway before it accepts the Trailer Detector unit J345. Then Code 2 Things : The Engine, & the PDC from memory.
