Tow Bar to work correctly requires a VW module. This is responsible for CAN communication with other modules:
- engine - when towing it works differently to cope with extra load - sometimes switches additional fan to cool
- ABS / ESP module - these work differently when trailer is hooked to avoid jack knifing.
- CECM - This power module distributes power in another way when trailer is hooked - also visually aids the driver when trailer is hooked on dashboard
- OPS - This is coded so when trailer is hooked up sensors do not beep
- CAN gateway - trailer module is coded into the gateway (main comms hub) so the car and other modules know what to do
- RVC - reversing camera - similar thing to parking sensors - recognises the trailer on the screen switches off dynamic lines
- 5F Information Electronics - ensures entertainment system displays all the trailer info correctly.
There is probably a couple of other which we are not aware of.
Overall when the proper VW / Westfalia module is fitted it is safer & easier for the car & driver to deal with the trailer. Many vehicles activate additional fan so the engine does not overheat (A5 cabrio is a great example).
