Originally posted by lenojd
View Post
Mk7 Golf R Discussion Thread
This is a sticky topic.
Originally posted by anduril View PostWhat I've been told by the service manager before I drove the car out of the dealership:
- Make sure you use the full rev range, the car has already been 'run-in' at the factory
- Don't let the sit in idle for too long (over 15 minutes)
- Don't sit on the same speed and rev level for too long (ie: cruise control on highway)
- Make sure the car is warmed up before you drive/push it
- Take the car on inclines/declines and down shift and let the car roll down
I guess different people will have different opinions on how the cars should be driven but all the above sounds reasonable to me.
The last point is about engine braking. You've seen those signs for truckies coming into towns about not using compression braking? They don't use their brakes unless they have to. Drop her down a gear or two and let the engine do it for you. It helps put pressure on the rings and seal them better so you use less oil.
It's all about pushing the rings into the bore. You only do this by accelerating flat out or engine braking. Accelerating in high gears is good and helps keep your licence.
If you have a car that uses a fair bit of oil think back to how you drove for the first 1000km. If it was at a steady speed with no hard acceleration and no revs above 4000rpm that might be why.
I drove mine as per andurils service manager and it's used 500mls in 25,000kms.Last edited by Paul_R; 14-05-2014, 08:02 PM.Looking for:- RS4 B7 Avant.
Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
Originally posted by Paul_R View PostI drove mine as per andurils service manager and it's used 500mls in 25,000kms.
Originally posted by samps View PostI totally agree about not babying your engine during run-in, but how did you determine that it used 500mL? On the dipstick that's the difference between measuring when the oil is hot and when it's cold. Or did you dump the oil and compare the volume to how much you originally put in?
Are you sure 500ml is difference between warm and cold? That seems a bit much. I thought the hatched area of the dipstick was about 1 litre from bottom to top.Looking for:- RS4 B7 Avant.
I believe that the reason was that in "the old days" it could lead to glazing of the cylinder bores which then allowed oil to bypass oil rings on pistons which is then burnt with the fuel and goes out the tailpipe (requiring oil to be topped up). TBH though with the advances in engine technology I don't believe any of these old running in techniques are necessary anymore! I certainly wouldn't take as gospel what dealership tells you UNLESS written in black and white from VAG. The (old) TFSI motor used to lose oil by evaporation from the top of valve train - hence why oil catch can was a common performance add-on. I have Tiguan with 2.0TSI and in 3 years of ownership have never needed to add a drop of oil between services and I did nothing different when driving it from the beginning. Having said all that, I'm not a qualified mechanic but I have had 20-odd years experience in heavy vehicle industry and dealing with lubrication companies so do have some experience with oil technology (which has also come ahead significantly in that time)
Upshot is (IMO) - if you're losing oil there most likely is another reason for it that should be investigated!2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
I thought the 'sitting for 15m' point was more to look after the DSG. Then again, I have seen older folk shift from D to N in their older Falcodores when stopping for more than a minute.
In response to the running in of the motor. I'm going to drive it exactly the same way I have driven my GTI. The GTI used about 700 ML oil over 32000km and 3 years.
Just make sure the engine is WARM - ie at operating temperature. Just drive it normally and give it a bit of a squirt every day.
No launch controls until 1000km.- Golf 7 R DSG White -
As for the Golf R. It's a precision piece of german engineering. Only picked it up yesterday and am very impressed with the overall build quality and finish compared the the MK6 GTI.
Took it down to Stanwell tops and back through the national park last night. Corners very nicely and accelerates out of corners with heaps of grip.
Pity you can't really open up the throttle in this country. We need an autobahn type highway between here and melbourne / brisbane I reckon!!- Golf 7 R DSG White -
Originally posted by Ohmang View PostPity you can't really open up the throttle in this country. We need an autobahn type highway between here and melbourne / brisbane I reckon!!
