110TSI - Fuel Filter Replacement?
  • 110TSI - Fuel Filter Replacement?
    Hey guys, I've got a 2018 110TSI and on the VW service website it says that the fuel filter is due for replacement at 60k km - I can't find anything online about replacing it. From what I've read it's just a strainer built into the fuel pump so does it actually have a seperate replaceable fuel filter?
    @ I CU2:Hi.
    Yes, the fuel filter is part of the Low-pressure fuel system. I'm not sure that it's a "strainer" - in cars that have a fuel leak detection system (like "Yankee" models), the filter is activated charcoal type.
    Hmm............ I don't have a manual for MY18 Golf- but the following is from the repair manual:
    Fuel_supply_system_-_Petrol_engines_Golf 2015
    5 Fuel filter
    Pressure limiting valve and fuel filter are integrated in fuel delivery unit and cannot be renewed individually
    Don
      Correct, its built into the fuel pump. But if you read the service line it says the following:
      "Fuel Filter - Renewed (Excluding internal Tank Filters)".
      So you are good to not do anything, unless you want to replace the Fuel pump
      2015 Carnival Yellow Honda S660​
      2023 MY23 Nevada White Cupra Formentor VZx
      2024 MY23.5 Moon White Skoda Scala 110TSI Signature
        It has a built in strainer to protect the pump and then a replaceable fuel filter at the rear under the car. I dont now how you searched online but easy to find both filters for sale and videos on replacing it.
        2013 Touareg V8 TDI R line and spanner on my sons Mk4 R32
