Hi Golfers,
HAs anyone used one of these oil extractors?
9L Waste Oil Fluid Extractor Pump Manual Fuel Suction Vacuum Car Boat Transfer | eBay
Specifications:
Color: White
Fluid Extractor Capacity: 9 liters/2.3Gal
Fluid temperature range: 35°F- 200°F/1°- 95°C
4x Polypropylene hose diameter: 4mm / 6mm / 8mm / 10mm
Working pressure: 70-170 PSI
G.W.: 3 kg
Package Including:
1x 9L Oil Extractor
1x Copper Rod
4x Extension Hoses (4mm / 6mm / 8mm / 10mm)
1x Manual
Will an Oil Extractor Get All The Oil? (MK7.5 Golf R 5000 Mile Service) - YouTube
[IMG]https://www.vwwatercooled.com/forums/image/svg xml;base64,PHN2ZyB3aWR0aD0iODgiIGhlaWdodD0iODgiIHZ pZXdCb3g9IjAgMCA4OCA4OCIgeG1sbnM9Imh0dHA6Ly93d3cud zMub3JnLzIwMDAvc3ZnIj48ZGVmcz48bGluZWFyR3JhZGllbnQ geDE9IjIuMDY2JSIgeTE9Ijk2Ljc1MSUiIHgyPSI5NS42NTklI iB5Mj0iMi45NjklIiBpZD0iYSI PHN0b3Agc3RvcC1jb2xvcj0iIzZEMDBGNiIgb2Zmc2V0PSIwJS IvPjxzdG9wIHN0b3AtY29sb3I9IiMwMDNBQkMiIG9mZnNldD0i MTAwJSIvPjwvbGluZWFyR3JhZGllbnQ PC9kZWZzPjxnIGZpbGw9Im5vbmUiIGZpbGwtcnVsZT0iZXZlbm 9kZCI PHBhdGggZD0iTTEyLjY3NiA3Ny4zNzZjMy45ODMgMy42MDggOC 42NjcgNi4yOCAxNC4wMjcgOC4wMTdDMzIuMDc4IDg3LjEyNSAz Ny44OSA4OCA0NC4xNjMgODhjNi4xNjQgMCAxMS45MzQtLjg3NS AxNy4yOTYtMi42MDcgMi4xNTQtLjY5NCA0LjE4Ni0xLjU0NyA2 LjExNi0yLjU0MyAyLjg4NC0xLjQ5IDUuNTMtMy4zMTIgNy45MT YtNS40NzQgMy45OS0zLjYwNyA3LjA5Ny04LjE4MyA5LjMzLTEz LjcwN0M4Ny4wNSA1OC4xMzYgODguMTY4IDUxLjU4IDg4LjE2OC A0NGMwLT****g2LTEuMTE4LTE0LjE0LTMuMzQ2LTE5LjY3LTIu MjMzLTUuNTMtNS4zNC0xMC4xLTkuMzMtMTMuNzA1LTMuOTg1LT MuNjE3LTguNjYtNi4yODUtMTQuMDMzLTguMDJDNTYuMDk2Ljg3 IDUwLjMyNiAwIDQ0LjE2MiAwYy02LjI3MyAwLTEyLjA4NS44Nj gtMTcuNDYgMi42MDYtMS43NDMuNTYtMy40MTIgMS4yMzYtNS4w MSAyLjAwNS0zLjMyIDEuNTgzLTYuMzMgMy41NzgtOS4wMTcgNi 4wMTVDOC42ODggMTQuMjMgNS41NzggMTguOCAzLjM0NiAyNC4z MyAxLjExNiAyOS44NiAwIDM2LjQxNCAwIDQ0YzAgNy41ODIgMS 4xMTcgMTQuMTM3IDMuMzQ2IDE5LjY3IDIuMjMyIDUuNTIzIDUu MzQyIDEwLjEgOS4zMyAxMy43MDZ6IiBmaWxsLW9wYWNpdHk9Ii 42NSIgZmlsbD0idXJsKCNhKSIvPjxwYXRoIGQ9Ik0zNi43MyA1 OWgtLjA2NmMtLjkyIDAtMS42NjQtLjc0Mi0xLjY2NC0xLjY1Nl YzMC42NTZjMC0uOTE1Ljc0LTEuNjU2IDEuNjY0LTEuNjU2LjAz IDAgLjA2IDAgLjA5LjAwMi4zOC0uMDczLjc4OC0uMDE0IDEuMT UyLjE5NmwyMi42MjIgMTMuMDZjLjc5OC40NiAxLjA3NSAxLjQ3 NC42MTMgMi4yNzYtLjAyMy4wNC0uMDQ4LjA4LS4wNzUuMTE4LS 4xMzcuMjctLjM1LjUwMy0uNjMuNjdsLTIyLjQ0IDEzLjQ4NGMt LjM5NS4yNC0uODUuMjk1LTEuMjY1LjE5M3oiIGZpbGw9IiNGRk YiLz48L2c PC9zdmc [/IMG]
with kind regards,
from Al <")))><
- 9L Oil Extractor: The manual oil extractor is made of high-quality polypropylene for durability and resistance to corrosion and rust. Its capacity can reach 9L, which allows you to store more oil and avoid frequent recycling waste oil.
- 4 Fluid Extractor Hoses: The manual fluid extractor comes with four suction hoses to change different sizes for various conditions. Along with the adapter, the hose can reach the very bottom of the reservoir and suck up every drop of motor oil.
- Specificaiton: Color: White; Fluid Extractor Capacity: 9 liters; Fluid temperature range: 35°F- 200°F/1°- 95°C; 4x polypropylene hose diameter: 4mm / 6mm / 8mm / 10mm; Tank Capacity: 9L; Working pressure: 70-170 PSI
- Easy To Use: You can change engine oil and transmission fluid by merely opening the hood, inserting an appropriate hose to the bottom of the oil pan. With the oil extractor pump, you no longer have to lift or crawl under the car to do fluid changing, and there is no mess to clean afterward.
- Wide Application: The fluid extractor is widely used to extract the engine oil, brake fluid, ATF fluid, and other non-corrosive and non-thick fluid of motorcycles and vehicles. It is perfect for working on cars in the garage or automobile repair shops.
Specifications:
Color: White
G.W.: 3 kg
Package Including:
1x 9L Oil Extractor
1x Copper Rod
1x Manual
with kind regards,
from Al <")))><
