Hi All, just wondering what other people are doing to clean/maintain their engine bay appearance. I generally just wipe the dust with an old rag/cloth and dispose it after use. Are there any tips for keeping the engine bay pristine?
Engine Bay maintenance/clean
So every 6 months or so i will give the engine bay a clean with some gentle all purpose cleaner and a high pressure Karcher. Just dont point the water directly at any electrical components. Then I use compressed air to blow water out of all electrical connections etc (although they are generally waterproof anyway).
Then every month or so I just wipe over with an old chamois that i only use for inside the door jambs and engine bay just to keep the dust under control.
I have used this method for many years on many different cars and never had an issue.
Originally posted by Veteran78 View PostDo you use any type of chemical to keep the plastics and rubbers protected?
I clean mine every 3 or 4 months, after a long drive such as going interstate the engine bay can be full of bugs and other various grime..
I spray it down with some of this stuff, works a treat Orange Agent - for safe and powerful cleaning.
Then hit it with the Karcher avoiding any wiring directly, you can also use plastic bags to insulate certain areas if you are worried.
Once washed, wipe down any plastics and puddled areas with a micro fiber cloth to avoid spotting, then go for a short drive around the block to warm it up and dry it out.2016 Golf R, APR Stage 1
2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
Originally posted by flat6 View PostI clean mine every 3 or 4 months, after a long drive such as going interstate the engine bay can be full of bugs and other various grime..
Once washed, wipe down any plastics and puddled areas with a micro fiber cloth to avoid spotting, then go for a short drive around the block to warm it up and dry it out.MY20 MK7.5 GTI - Solid White
MY23 T-ROC STYLE - Silver Metallic
