Project 145TSI
  • #91
    I've really enjoyed reading this thread too, definitely inspired me to start modifying my own car!
    Sent from my SM-G986B using Tapatalk
    • #92
      So a busy weekend to finish this project off ....
      1st off
      Fitted a Turbo Intake Pipe from MST. This is new on the market and should add another few kw
      Noticeable improvement over stock
      Intake sound is a bit deeper and the blow-off more pronounced. According to MST, even a stock diverter can be heard with this new TIP.
      I'm expecting to be around that elusive 150kw mark now for the 110TSI. Such a nice drive now.
      Would be interested to see the dyno results. Have you upgraded the intercooler? Maybe next thing on the list... If you're still running the stock one it could be quite restrictive at the power levels you're running now.
      2nd off the big job of fitting the SuperNova LED headlights ....
      This is a full bumper off job, lots of clips in weird places and lots of electrics to disconnect from sensors. It was a good learning experience though.
      Does look pretty good fitted
      [ATTACH=CONFIG]51955[/ATTACH]
      Wow! Finishes it off. So much nicer than those stock halogens.
      - Tigger73's 125TSI Build
      • #93
        New headlights look leaps and bounds better than the original halogens. And you can never go wrong with some power mods too
        B9 Audi SQ5
        • #94
          So, being slightly bored on a Friday afternoon I researched some random stuff (mostly Up! related for that project), but found this ....
          Downpipe VW Audi Seat Skoda 1,2 1,4 TSI Exhaust Stainless Steel 200 Cell Kat | eBay
          Stainless sports downpipe for the 1.4TSI with a sports 200 cell cat .... claimed 11kw in it .... will this take me to 160kw?
          It is soooooo tempting
          • #95
            Are you really expecting us to say anything other than: "DO IT !!!" ?
            • #96
              Ben
              2015 Polo GTI & 2019 Golf R
              • #97
                Hey Sharkie love the thread on your build i have the dsg version just done a res delete and now looking for for the mst cai u got for your car did you get this in australia or from over seas
                Also would you have the part number for the rear bar valance the vw dealers in perth are a bit incompetent
                Thanks in advance
                • #98
                  I got all the bits from MST direct MST Performance Auto Part
                  They ship to Australia and is normally pretty quick.
                  Lots of 1.4TSI bits on there
                  • #99
                    Sweet thanks for that i have looked there wasnt sure about shipping
                    • Originally posted by Sharkie View Post
                      1st off
                      [ATTACH=CONFIG]51948[/ATTACH]
                      [ATTACH=CONFIG]51949[/ATTACH]
                      [ATTACH=CONFIG]51950[/ATTACH]
                      [ATTACH=CONFIG]51951[/ATTACH]
                      [ATTACH=CONFIG]51952[/ATTACH]
                      Hi Sharkie,
                      what are yours thoughts about the new inlet pipe since you installed? I want to do as well but the cheapest place I could find is around $200+shipping and I want to find out if it worth it.
                      Thanks.
                      Golf Wagon MK7 (90 92TSI) - Mods: DQ250 swap (Stage 2), 110TSI turbo upgrade (Stage 2), Bilstein B12, 19" Pretoria, GTI PP sway bar upgrades (front/rear), full GTI tartan interior, GTI colour cluster, R Bi-Xenon headlights with AFS retrofit, GTI brake upgrade.
                      More to come...
                      • Originally posted by Gutoneto View Post
                        Hi Sharkie,
                        Thanks.
                        I think every bit helped so far. It is an incremental improvement and that gains are small for each but combined I'd be at or close to 150kw now. If you look at the standard TIP, you can see its pretty bad and not conducive to nice flow, so I'd do it again without a thought.
                        Get it here Volkswagen EA211 1.2/1.4 turbo intake pipe (VW-MK70 for about $150 + shipping. Although I'd probably do the CAI before I do the TIP.
                        BTW, I see you have a 110TSI turbo on a 90TSI .... how did you do that, simple bolt on and then tune with a 110TSI file? I'm keen to do that for the A1 (92TSI).
                          I've been looking to the website for a while as they still out of the stock for months now... Searching for the part number I could find another shop that has in stock but for quite extra money.
                          I was thinking to do the turbo intake first as I still not made my mind yet about the air intake, if I go CAI or stay using the inbox one with a K&N for example.
                          I had to do some deep research but found out if you use specific turbo models from the 110TSI you won’t have any problem with the wastegate and car going to limp mode. The turbo is bold on. The injectors are pretty much the same and because that, the ECU’s closed loop can handle the changings without need to flash the car to the 110TSI file. I used like that for almost 6 weeks (driving around 200km per day) before I had time to do the stage 1. Now my car has the 110TSI tune to 140kw.
                          Even my car been a 2014 model I managed to get a new turbo from a 2020 model with less than 5000km from a wrecker and been running so far so good for the last 5000km.
                          More to come...
                          • Hello there ,im just new owner vw golf 2018 TSI 110,is anyone try the remapping from supercheap stage 1 (29hp)?
                            (VW) Volkswagen Golf MK7 110 TSI Tune, ECU Tuning, Chip Tune & Flash Tune
                              The entire intake side has lots of chambers/pipes etc that impact on good flow to the turbo. Both the TIP and the pipe between the TIP and the airbox has extra voids that cannot possibly be good. You can keep the stock airbox provided you change the pipework between it and the turbo.
Name:	MST Inlet 1.jpg
                              Also, what tuner did you use?
                                [ATTACH=CONFIG]52948[/ATTACH]
                                [ATTACH=CONFIG]52949[/ATTACH]
                                I see what you're saying, definitely I'll try to get the whole inlet pipe.
                                Regarding the tuner... that was a drama.
                                I was in the market to get a second had car and an A4 Avant always was my first choice. As the current second hand market is going quite crazy at the moment I could find nothing that it worth to buy it for the budget I had in mind. Then I suddenly found this thread and it make changed my mind. I do have in mind all the mods I want to do it and something always was in the first ones was to do the tunes (ECU and TCU). I don't want to go crazy but as the same as your one ~140KW+ (pretty close the MK5 GTI) would make me very happy.
                                The APR reseller didn't want to touch my car as he said he doesn't do tunes with DQ200 cars, as I told what I had in mind (~140KW, MK5 GTI and so) he told me to sell the car and buy a MK5 GTI instead... frustrating
                                I checked with HP as you mentioned about the DSG Tune but I found their prices a little bit higher from my budget, don't get me wrong but I had a set budget in mind and just for what they charge for the DSG tune I got both done.
                                Revo when I told them that I had a turbo upgrade they said it would be best to get someone to tune the car on a Dyno.
                                Then I spoke with a Celtic tune reseller near where I work and he was very good and agreed to get both done for me.
                                I'm quite happy now.
                                More to come...
