Mechanical help please --- I have a question, my manifold inlet runner was replaced by VW ( thanks to head office) over a month ago on my 2010 gti. 45000km. Will this be an ongoing issue with the carbon build up which means I will be up for another inlet runner? Or Is a oil catch can an option to prevent this from happening again?
Manifold inlet runner / oil catch can mk6 golf gti
You would be wise to add a catch can system, as it will only help, but so too it does not stop all the blowby. The other option is to use the various upper intake cleaners, available at Supercheap etc, every now and then, and keep the buildup down. It is a huge problem across a lot of brands, you should see the issues Ford is currently having, makes VW look great.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
or drive it very fast for 10-20mnts every month or 2. dont have to becompetitively fast.
happy laps events were my italian tune sessions
never had any intake manifold issue with my mk6 gti.Mitsubishi Pajero Sport - Super Select 2WD/4WD
MINI Cooper S Clubman - FWD
Hahaha I shouldn't have a problem in that department
Originally posted by nat225 View Postor drive it very fast for 10-20mnts every month or 2. dont have to becompetitively fast.
never had any intake manifold issue with my mk6 gti.Volkswagen Mk7 Golf GTI 40Y Clubsport
Tuned by Tarmac Engineering / Spectune
@ Bayside Performance Services Cleveland Brisbane
Good idea Greg, I messaged you on Facebook the other day about the 42dd catch can. If I work it out $500 catch can versus a $1000 minimum VW runner I think I would add one.
Originally posted by Greg Roles View PostYou would be wise to add a catch can system, as it will only help, but so too it does not stop all the blowby. The other option is to use the various upper intake cleaners, available at Supercheap etc, every now and then, and keep the buildup down. It is a huge problem across a lot of brands, you should see the issues Ford is currently having, makes VW look great.Volkswagen Mk7 Golf GTI 40Y Clubsport
Have you been thinking about a catch can to reduce the risk? BTW how come you removed your Carbonio?
Originally posted by Reedy View PostI too have a 2010 GTI, I've had mine changed at 50000klm, then at 100000klm this one I'm on now has lasted the longest. Not sure if the last one they put on was a revised part.
Good luck.
Sent from my iPhone using TapatalkVolkswagen Mk7 Golf GTI 40Y Clubsport
I think catch cans are only good for the Golf R. I removed the intake as it caused fuel trim issues with my bluefin tune. Just as it was asking for all the boost at certain throttle positions it would hesitate. I put the stock box back on and wow! Perfect. I've been running the BSH intake for a few years with no issues but now I'm back to stock box. I just swap and change when I get bored.
Sent from my iPhone using Tapatalk2015 Golf R. Lapiz Blue.
I never thought to test that as bluefin wanted an air intake upgrade. I always thought mine was a bit off.
Originally posted by Reedy View PostI think catch cans are only good for the Golf R. I removed the intake as it caused fuel trim issues with my bluefin tune. Just as it was asking for all the boost at certain throttle positions it would hesitate. I put the stock box back on and wow! Perfect. I've been running the BSH intake for a few years with no issues but now I'm back to stock box. I just swap and change when I get bored.
Catch cans will improve the long-term performance of any engine that recirculates and burns its crankcase fumes — unfortunately they won't get 100% of the oil (I think you'd need both filtration and refrigeration for that,) but every little helps.Originally posted by Reedy View PostI think catch cans are only good for the Golf R.
Afraid I gave up 42DD some time ago, when the dollar dropped, and there was no way to keep the prices competitive with direct import. There are several truly excellent catch cans out there now, all you need for a VW specific one is the adapter plates and manifold tap, for the FSI engines anyway. Nobody I know of has a proper system for the TSI and its more complex twin blowby outlets.Originally posted by Mdanrex View PostGood idea Greg, I messaged you on Facebook the other day about the 42dd catch can. If I work it out $500 catch can versus a $1000 minimum VW runner I think I would add one.
I believe in catch cans that much that I actually have 2 of them in series in my TDI, and my inlet is dry at 50,000kms, just EGR soot, and minimal at that. I still had number 1 cylinder inlet valve stem buildup, which is one of the two main issues of blowby.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
CTS have a good one for the 2.0TSI engine. The PCV plate machining is pretty awesome.
CTS Turbo MK6 TSI Catch Can Kit
That was the one I've been looking at, but can someone explain what the noise pipe delete kit is and why would I want to delete the noise ?
Originally posted by Lucas_R View PostCTS have a good one for the 2.0TSI engine. The PCV plate machining is pretty awesome.
CTS Turbo MK6 TSI Catch Can KitVolkswagen Mk7 Golf GTI 40Y Clubsport
If I had the knowledge I would do that too Greg
Originally posted by Greg Roles View PostAfraid I gave up 42DD some time ago, when the dollar dropped, and there was no way to keep the prices competitive with direct import. There are several truly excellent catch cans out there now, all you need for a VW specific one is the adapter plates and manifold tap, for the FSI engines anyway. Nobody I know of has a proper system for the TSI and its more complex twin blowby outlets.
I believe in catch cans that much that I actually have 2 of them in series in my TDI, and my inlet is dry at 50,000kms, just EGR soot, and minimal at that. I still had number 1 cylinder inlet valve stem buildup, which is one of the two main issues of blowby.Volkswagen Mk7 Golf GTI 40Y Clubsport
The FSI engine is easy, you can buy just the blanking plates and put whatever catch can you fancy in. The GTI with the TSI needs the "Africa" plate as it is often called, and I don't know of anyone selling it separately. I also know that this plate alone isn't a total solution, as when it was first developed by Forge, they had plans to re-design it, and given the complexity, to my understanding that has not yet happened. I know when I stopped 42DD they were also working on a TSI solution, but again I think no final outcome there either.
Your call, but on a GTI a $25 can of Liquimoly upper intake cleaner from Supercheap every few months would be a real option, especially on the TSI.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
