Car splutters/mini misfire at low rpm
I have developed or only just noticed this spluttering or very little misfires I have at low rpm's. When cruising in 6th doing 60klm/hr the revs sit at 1400. It's at this point the car begins to splutter only very slightly but noticeable. This happens also when I just sit and just rev the car to 1400 rpm. It will kind of cough now and again with a little splutter, as soon as I add more throttle past 1800 rpm you can here the whole car just run smooth. These symptoms are worse when the engine is cold.
The fuel filter and plugs are less than 15000klm old and its not the coils as I've put an old set on I have and it still does it. The car pulls hard with no misfires, it just seems to be at these low rpm's, you can also see the rev counter needle wobble at these low revs and as soon as you hit 2000rpms smooth out.
I'm going to check the plugs today and there gap but with this problem only being at certain rpm's I can't see it being them.
Any ideas what else it could be or has anyone else had the same issue. The car seems to idle ok but has the rough idle when cold as it sits right at the 1400rpm mark. I've just done over 100000klm now and just had the throttle body cleaned by VW with no success.
Thanks for your help.
Adam.
Adam.
