Car bucks and jerks when cold below 2000 rpm
  • Car bucks and jerks when cold below 2000 rpm
    When ever the car is cold and I am driving or stood still just feathering the throttle the revs seem to do what they want to do which is jump around. When stood still they just jump around until I rev over 2000rpm, when driving this causes the car to buck and jerk.
    Anybody any suggestions regarding what to test check or replace.
    Once the car has warmed up the symptoms are not nearly as bad and hardly noticeable.
    Cheers.
    2015 Golf R. Lapiz Blue.
    Is it misfiring? If so, it will be the ignition coils which are a common failure on these engines. Good news is that they are not very expensive and can be had for about $150 (full set) delivered from USA. Be prepared to pay double that (at least) to source them from your local VW.
      Let the car warm up before driving all cars will idle differently when there cold it's just the programming of the ecu they all have a warm up phase if you feel it's ok when its hot this may be why.
        Thanks for the response. Symptoms have developed on the way home. I have been getting a little flutter of the rev counter when moving and I press the throttle. These has developed into when at idle and I push the throttle it kind of misses a beat and then revs. These are the exact symptoms I had a year ago and it turned it to be the purge valve and charcole canister. These symptoms maybe related to the bucking I have when cold. Car is booked in for next Tuesday. Don't really want to be buying a new purge valve and charcole canister every 20000klm?? There is a thread started by me some on this forum about this issue I had.
        I'll keep you all posted.
          First i've heard on here of a purge valve (?) and charcoal canister having to be replaced, so hopefully that was a one-off. I'd say ignition coil packs are the culprit this time.
            Back on the 12/12/12 I had a discussion on this started by me I think titled engine flutter or rev counter flutter.
            I've just fault tested my car with my little cheap tester and faults are:
            01089
            P0441
            After researching these they all point to the purge valve and charcole canister. I must be the only gti owner to be having this problem. I thought it was a year ago but I had a new one fitted last December so 8 months ago. Not good.
              Ok well the purge valve and charcoal canister are related (both part of the emission control system on the engine) so makes sense that you are getting errors for both.
              Given that this has happened twice in a short time frame, id say it's either incredibly bad luck, or more likely, another part in the emission control system that's faulty and causing these parts to wear out faster than they normally would.
              Some info that might help - turns out in this case it was the "fuel pressure limiting/regulator valve" that needed replacing. Another common culprit seems to be a vacuum leak (pipe or connection is cracked) or a pipe is blocked.
              VWVortex.com - Stubborn P0441 code
              16825/P0441/001089 - Ross-Tech Wiki
                Thanks mate, I hope that because its been a short time the VW will perhaps look a little deeper, or I may suggest they look deeper as main steelers can be lazy... I'll keep you all posted.
                  Faults cleared by my maxscan and half the problems are gone. Still got the bucking and jerking below 2000rpm when cold but the purge n80 valve symtoms have gone or appeared to have gone for now. This thing is driving me crazy!!!!!!!! But still love it.
                    Get these ALOT. Seen guys replaced N80, charcoal canister and breather valve on rocker cover all as a set, usually just for $$. The culprit is 9 times out of 10 the N80, charcoal canister very rarely will block up in a cars lifetime, let alone a second time after its already been replaced. You said all that stuff was fitted 8 months ago, take it back to where it was fitted tell them it's back again, remember 12months part and labour warranty mate. Goodluck.
                      I've also got a similar fault with my car - just under 3 years old - 50K GTI DSG
                      When it's cold it misses pretty badly, it's especially bad around the 1000-3000rpm range under load.
                      Off throttle and idling it seems ok , maybe a touch rough on idle.
                      I can watch the oil and water temp and when they get to running temp, about 6mins, the car is fine.
                      The car did show some error codes and I've had the N80 valve, Evap can Tube & Evap Canister replaced.
                      But after this it's still doing it.
                      As it only does it for about 6min when really cold it's tricky to show.
                      Has anyone had this issue and had it resolved?
                      MY21 Golf MK8 GTI | Kings Red Metallic | all options |
                      MY16 Golf MK7 GTI PP | White | With Leather |
                      MY11 Golf MK6 GTI DSG | CW | 5dr | Bi-Xenons | ACC | 18" Detroits | RNS510 with Dynaudio| RVC | MDI |
                        I had a stutter between 2000 & 3000 rpm, only when the car was cold and after about 5 mins it went away.
                        Problem solved when engine temp. sensor replaced, no codes came up when car was scanned.
                        mk VI GTI, manual, reflex silver, basic
                          Interesting do you happen to know what the part code of the sensor was by any chance?
                            Sorry, I don't - my mechanic changed the sensor as a trial, so I didn't get any invoice for it. he did the make the comment that the dealer where he buys his parts from said they were supplying a couple of the sensors every week.
                            The sensor apparently adjusts the fuel metering according to the engine temperature and if sending the wrong signals doesn't adjust the fuel metering when the engine is stone cold, but it only takes the engine a couple of minutes for the engine to warm up sufficiently.
                              Looks like my issue was something different, I've just had one of the Injectors replaced and now the issue has gone.
                              Luckily it was done under warranty.
