How to Disable ESP
  • How to Disable ESP
    Engine Computer Hackers Show You How To Disable The VW Golf R's Stability Control
    Above is a link on how to disable ESP on a Golf R using VCDS.
    Remember Caveat Emptor.
    How to Disable ESP on Golf R
    R's post June 2011, you can disable it much more easily though cant you ?
    Hold the button down until both are off
      The console doesn't actually let you totally disable ESP - it just puts it in a milder setting.
      Love to hear from someone who tries this mod
      Resident grumpy old fart
        Really ?
        I thought MY12s post June 2011 it was a new system that allowed it totally off
        For track, value is there but no value whatsoever for road use
          Originally posted by Candyman View Post
          Really ?
          What he said
            Link: Golf R ESC DIY
            Don't see the point of it in my case since I'll never be on a track and FWD cars will just understeer.
            Audi A3
              That is for the US R though ?
                So will this work on a 2011 or is it just post 2012 and us models???
                YAY I got my R!!!! White, recaro seats, 19" wheels, bluetooth, reverse camera
                  Really ?
                  Not quite. The ESP can be put into a suspended state, but if you touch the brake while you're having a moment, the car will automatically re-enable it. This is a safer compromise for road use, but still doesn't make the car 100% track-friendly. In the US, they don't even get that feature - it's ESP-on all the way.
                  The mod being discussed on VWVortex will disable the ESP completely - it won't be re-enabled by a touch of the brakes. Only by switching ESP back on or restarting the car will it kick in.
                    Apparently you need this specific ABS Controller hardware, and this (or later) software:
                    Originally posted by VWVortex
                    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
                    Component: ESP MK60EC1 H31 0121
                    Revision: 00H31001
                    Apparently a part number ending in BG may also work in some cases. However, these parts appear to be specific to late 2011+ build Golf Rs, GTIs, TSIs and TDIs, Skoda Octavia, etc.
                    Several Golf GTIs with this same ABS Controller have also accepted the coding change and will allow the ESP to be disabled. AFAIK it's just US and Canadian cars that have been coded successfully thus far.
                      Ah yes, I did encounter that "brake on" activation not longer after getting my R
                      Someone needs to get clever and have either a quick switch to flick it off after braking or code out the brake on effect ?
                      Is that even possible.
                      Still, I'd rather use a car like an MX5 for track use or something like the turbo enabled 86 that was at the Hot Tuner challenge than a Golf R
                      The R handles like a wet sponge without some serious suspension work
                        Well, that is the question. And I'd say the answer would come down to the version of ABS Controller in your car. I'd be surprised if a coding change would disable ESP for controllers prior to late 2011, as VW didn't offer that feature on the Golf in any market (that I know of).
                          Just tried this in my MY11.5 Golf R and the new coding was rejected
                          Must only work on North American vehicles.
                          B9 Audi SQ5
                            What version of the ABS module do you have, Lucas?
                              How to Disable ESP
                              Absolutely no idea Adam - will try and find out
                              B9 Audi SQ5
