LED Number Plate Lights
  • I bought these for MY12 GTI:
    eBay Australia: Buy new & used fashion, electronics & home d
    $45 shipped including adaptor cables and work fine, no errors or faults, simple plug and play.
    Forever blowing bubbles.
    • just to confirm led plate lights with adapters DO NOT display bulb out msg?
      GTI carbon steel g, leather, mdi, A.C.C., park parallel assist & RVC, dynaudio, sunroof, R-tails, RNS510, 9WZ, LED reg
      • Originally posted by night_flight View Post
        That all depends on the particular lights and adapters you're referring to.
        I have the RDash LEDs myself, and made up some custom resistors for them (after disassembling my first set of RDash heatsinks - the first set were faulty and they sent me a second set), and they work a treat. Very low heat and no bulb-out errors at all, thanks to the spec of resistor I've used.
        There are various LED and adapter/resistor combos available, many of which work fine.
        • sorry i was referring to the OEM ones OEM Euro VW Golf MK6 LED number plate illumination adapter - BKS-Tuning with lights too from "we recommend" link
          • I previously had the globe LED's, but after a week or so, they blew.
            Ended up buying the full LED housing that you find on ebay for $45... heaps better.
            • I got these on my car: LED Numberplate Lights - VW Golf | SlickOnline - AutoSlick & HomeSlick.
              $55 including shipping and resistors so they are error free. plug and play. nice and bright.
              My Car: 2014 Subaru STI, Pearl White, Weather shields & Tints ETA 30/6
              Family Car: 2014 Audi S3 Sedan, Glacier White, 19's, Performance Pack & Sunroof ETA 31/8
              • Originally posted by will86_ View Post
                ^ They are worth every cent if your after a bright look. I've had them for over 1 year on the mk6 golf with no issues at all.
                GOLF | GIAC | CTS K04 | 215.9kws atw
                • Has anyone bought any of these lately and has a link/recommendation, the 2010 gti I bought second hand has them fitted but one just blew...
                  • We have two types in stock:
                    JOM - license-plate-leds-2pcs
                    led-numberplate-lights-volkswagen-vw-golf-v-vi
                    • Originally posted by AutoSlick View Post
                      can vouch for the ones selling off autoslick. I've had mine for 6 months or longer without fail. even better, no error light on dash
                        why are the JOM ones more expensive than the latter ones?
                        Thanks.
                        MK6 Golf 90TSI
                        Silver
                        Manual
                        • The other has some seriously large butt ugly resistor banks (but I suspect with coding, you could avoid needing to fit them).
                          • Originally posted by tonymy01 View Post
                            ^ as mentioned by tonymy01 - the cheaper (Racing Dash) LED's have a little resistor/heat sink box (about the size of a match box) that is needed in order for the LED's to work properly. They fit up inside the bumper cavity and use double sided tape to secure on a ledge. Mind you, there are stacks of Mk6 users with these Racing Dash lights (including myself) and they work perfectly. No errors, no issues and super bright.
                            These JOM units are new to the market, and i have not seen any photos of the light output that these give. Until these JOM units became available, the only option was the Racing Dash brand and another brand which i cant recall the name of right now. But Racing Dash were the more popular ones.
                            I like the fact that the JOM units don't need the resistor box, but they only have 3 LED's so the light output will be less than the Racing Dash units which have about 18 LED's or so.
                            B9 Audi SQ5
                            • I used to use the Racing Dash lights, with custom adapters I soldered up (the RDash heatsinks were rubbish quality and occasionally caused a fault code for me). That solution worked well - as mentioned, they are bright and throw a fairly uniform light - until the wiring into one of the LED housings started to fray at a point that was difficult to access or repair, causing the light to cut out intermittently.
                              So I bought OEM LEDs and adapters from carsystems.pl; cost about $100 all up. The light is far dimmer than the RDash LEDs overall (they utilise two large LEDs rather than 10+ smaller LEDs), but also draw a lot less attention to the numberplate area. Overall the look is much more OEM. The only downside of this for me is that it's now harder to see the ground via the reversing camera when backing up at night. The build quality of the LEDs and adapters is vastly better than the RDash units - as you'd expect given the higher cost.
                              • Ended up getting these from auto slick and can also recommend them. Good product.
