Retrofit of RVC to MK6 Golf
  • Ι must first thank you for accepting me in your big community
    I have exactly the same problem with my new RVC and OPS in my Golf MK6.
    Here is a picture of the problem in order for all of us to understand it better:
    Any help would be very much appreciated.
    Thank you in advance!
    • Originally posted by ozmale View Post
      Does anyone actually have, and could post the coding for getting the RVC and OPS on the same screen ?
      Chris
      I think you just have to upgrade your RNS firmware to get that
      Audi A3
      • Thank you for your answer!
        I forgot to say that my RNS is LED version with latest available software 38xx.
        ---------- Post added at 07:52 AM ---------- Previous post was at 07:16 AM ----------
        And the answer i think is in the following link (PDF in the first post):
        DIY Rear View Camera (RVC) installation on Golf "R"..
        • Might be slightly off topic or answered previously but did a quick search with no results. Is there anyway to get the steering indicator lines on the RVC display similar to the Passat in a Golf?
          • I think that the not moving yellow lines are coming from the controller of the camera.
            I installed the original badge camera into my Golf MK6 and i have this lines (of
            cource they are not moving with the steering wheel because this operation
            is coming from another extra separated from camera controller in the steering
            wheel column).
            • Originally posted by Rays_R View Post
              Only if you could fit the Passat setup, which wouldn't be easy, if possible at all. It has a separate controller, the Golf unit is all contained in the badge/latch assembly and not linked to the steering.
              • Is there any easy way to find out if my RCD510 has a video input without removing the head unit?
                MY12 MKVI Golf GTI DSG
                MY16 MKVII Golf 92TSI Tendline DSG
                • Originally posted by heyimsu View Post
                  Not as far as I know of. But AFAIK all RCD-510s being made these days do have the video input, even if not specced with the RVC from the factory. Seems to have been that way since around MY11.
                  • I'm thinking about doing this to the new cab since the back end leave a little to be desired in the field of vision department...
                    Have to keep digging to see where the wiring can actually run in this car since I don't have a roof cavity to play with
                    • Cool - be sure to let us know and take pics of any differences in procedure with the cab
                      Audi A3
                      • Seems like ECS tuning have released at RVC kit with all the wiring for $560 delivered. Looks like a pretty good deal imo. Not sure about the MK6s but the instructions for the MK5 involve cutting off some metal and a wiper blade mount to install this. Coding looks simple enough.
                        Home Page > ES#1905735 Reverse Camera Kit - 1K0998025
                        • Am I correct in thinking that this kit is somewhat more plug'n'play than previous jobs? Might be just what I need, perfect timing for taking weeks off work.
                          Audi A3
                            http://www.ecstuning.com/stage/edoc/...eraInstall.pdf
                            There is no cutting or removal of the wiper assembly for a Mk6 installation. However the coding is a little more complex.
                            See my DIY here
                            The Car: MY20 Black Golf R Final Edition, 5 Door, Driver assistance package, Sun Roof.
                            • Yeah I've got your guide saved at home as well for 'just-in-case', but the ECS kit looks a tiny bit easier (don't have to build a loom)
                              ---------- Post added 06-12-2011 at 01:39 PM ---------- Previous post was 02-12-2011 at 11:42 AM ----------
                              I think I might take the plunge and order the ECS kit and use a combination of their guide and ozmale's. Hopefully the weather will be good (not too hot or raining) when I get around to fitting it.
                              Audi A3
                              • Agreed on this - the ECS kit looks great, will be ordering one of these close to christmas - Happy days!
