Pump / motors / fans run after switching ignition / car off
I don't know if this has been asked before, on my 2010 Golf 2.0 TDI I have noticed on 2 occasions that the fan (front of engine) is still running after the car ignition is switched off and this can last up to 5 mins, I know the engine does make the odd noise or two when the engine is turned off anyway but is this normal for the fan still to be running.
Has anybody else noticed this, is it specific to the TDI's or is there a problem.
Any feedback would be greatly appreciated.
2008 Audi S3, Phantom Black Metallic, 6 Speed Manual, Sunroof, Leather, Bose Stereo, S3 Black Optics Grill, 2011 darkened Rear lights.
It's perfectly normal operation and detailed in the owners manual IIRC. Many cars do this after shutdown to cool the engine.
7. Q: My radiator fan started running loudly when I {turned off the engine or got off the highway onto surface streets or stopped at a light}. What's that about?
A: Your car was in the middle of regenerating the Diesel Particulate Filter (see Q4, above). The DPF gets very hot in this process. When your road speed drops too low to provide the required cooling, your fan turns on. When idling, you may also notice that your idle speed increases slightly to 900 RPM. You can prolly learn more than you ever wanted to know about DPFs and regens by reading these two threads:
The TSI motors have an auxiliary electric coolant pump that also runs for a few minutes after shutdown to keep coolant circulating through the turbo. This pump makes a faint 'buzzing' noise that you can hear after the radiator fan has turned off. It cools the turbo bearings down and stops them cooking the oil. Other manufacturers (eg Mazda) don't do this and consequently have a higher incidence of turbo failures.
i know this is going to be a stupid post but being a first time vw/turbo/GTI owner im unsure if its normal:
I noticed something last night which is the first time it has happened - i went on about a 45min drive (normal), engine temp was around the 95deg mark (normal), and came home; turned off the engine, got out of the car, and heard a noise coming from the engine bay that sounded like a fan..... i assume its the engine cooling itself after being switched off but it has never happened before....
is this a normal sound or is it wierd? why wouldnt it have happened before.... ive just hit over the 2000km mark so ud think it would of happened before this....
Unusual that you've only just noticed it now. The turbo fan on my car is switched on after virtually every drive, including the gentler ones (my oil tends to hover around the 97-99 degree mark in usual driving).
For the 12 days I've had my GTI, only once did the fan stay on after I switched the car off and this was not after one of the longer drives BUT that particular day was warmer than the rest. Didn't check the oil temp though.
This cooling down period is expected of a turbo car as mentioned by teodeh and in other topics in this forum but I find it a bit inconsistent of when it actually decides to 'activate'. Worth paying attention (myself included) to the oil temp as AdamD have suggested.
[MK6 GTI MY11 CW 3-door DSG Sunroof Detroits Dark Tint R LEDs APR Stage 1 (regrettably a few years late)]
