Pump / motors / fans run after switching ignition / car off
Does it gradually get softer and softer or is it a whine that goes on for abit and suddenly ends?
If it is the latter, then I would say it's the coolant after-run pump; shouldn't always run after every drive - it depends on how warm the engine is, etc.
Does the noise go away when clutch is pressed in???
Given it's a DSG, I think he'll be hard pressed to press the clutch in.
As per DNA Tuning, I'd say it's likely to be the pump cooling the turbo after the engine is shut off - especially if you hear a loud click when the pump switches off.
If you're not sure, just drop by your closest dealership and have them check it out, for peace of mind.
I figured it was a cooling of some sort, but it was really noisy, so not sure if it should be that noticeable...
Its quite noticeable, even when I first got my car back in March, I was like huh?
Its nothing to worry about it. Yeah it sounds quite loud, but after 30secs or so, it'll just turn itself off. Having said that, the fan sometimes doens't turn on - depends on the temp. outside.
I work at night, and when I drive home at 1am (esp. during winter) after a 10mins drive then turn the engine off, thn fan isn't running i.e. you can't hear the noise. So I assume its a cooler fan of some sort.
Lately, the fan has been coming on when I come home at night, which I attribute to the warmer temperatures at night.
Nothing to worry about!
MY11.5 118TSI - Reflex Silver Metallic, RNS-510, RVC + Park-Assist.
Delivered March 2011 and on the road
