  • Originally posted by DeanCorp View Post
    and can you get an Evoms intake while your at it. I want to see how it compares to Fab_R's, same car, different exhaust and one is manual one is DSG. This will be interesting
    Hey Dean...I dont hold too much faith in my dyno results given andret's results here.
    Im going to get another dyno run in elsewhere in the very near future...
    • Originally posted by andret
      totally correct fab_r - dyno's reading are all different - all I'm interested in is seeing the gains - I unfortunately didn't get to dyno the stock car. I wouldn't be concerned about dynoing if you've already proved a 0-100 4.26 sec (was that on vbox or something similar)
      Nope was not on a vbox..Let's not start this up again..
      There is nothing wrong with RE Customs Dyno.
      Andret what I would suggest is you go and get another dyno run elsewhere just using rollers as it seems a little high. But then again it could be the different exhaust that has made the difference over Fab_R's setup.
      Genuine VW Parts Importer | Navigation | Bluetooth |
      Repairs | Lighting | Coding | Programming |Cameras
      • Hey Andret,
        This looks awesome!! Very nice bit of kit. Costs around?
        And was that on a roller dyno or a HUB? (HUB obviously read out higher! If not thats some pretty good numbers there fella..
        Nice Pics!
        2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
        2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
        • Originally posted by REXman View Post
          +1. Really does look awesome!
          • Originally posted by Corey_R
            You mean like this?
            Dyno Results
            APR 1 Without custom exhaust
            (189KW)
            APR 1 with custom exhaust
            (192KW)
            So the exhaust is just for sound and looks? I would have expected much more than 3KW gain...
            Current: MY18 Golf R 7.5 DSG - FOR SALE
            Previous: MY11.5 RBR DSG
            • Originally posted by chylld View Post
              Most "Cat-back exhausts" (which don't replace the cat, btw) are just for sound and looks! On modern turbo-based cars, most of the cars to be had are in the downpipe (which is connected directly to the turbo) and the catalytic converter with a "high flow" or "motorsports" version. The cat is replaced with the downpipe - sometimes called a front pipe or dump pipe.
              Once the downpipe is replaced, you can then also run a Stage II turn. In any case, the peak power is still not a big jump. But since back pressure on the turbo is reduced, spool times improve and come at lower RPMs and the power band is widened.
              • Originally posted by Corey_R View Post
                Thanks for that Corey
                • 3Kw is peak.
                  The DP should improve spooling, and midrange may be lifted too.
                  There are other factors like throttle response too, which may improve driving experience, but not reflect on a dyno.
                  (edit: oops, seems corey beat me to it, need to refresh before i start typing)
                  2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
                  • oil leak
                    Has anyone that owns a Golf r experienced an oil leak?
                    Notably after first checkup/service, prior to this there were no issues
                    Any ideas what could cause there/if there any easy fixes?
                    • Originally posted by pumped View Post
                      i'm assuming you're seeing some puddles on your garage floor... it might just be AC condensate. dip your finger in it and see if it's clear
                      • Theres puddles but they arent water
                        Clear/clean oil
                        Looking underneath the car theres quite a bit of oil around , I'll try post a picture soon.
                        Only just discovered it this morning
                        • check that ur oil filter is on properly!
                          84 MK1 GTI
                          01 DC2R
                          • Originally posted by Guy_H View Post
                            FYI, Oettinger & APR no longer share any financial involvement, Oettinger have new Owners & are continuing along their own development path. They have their own engineers / calibrators & development facility.
                            The warranty is a big part of the product (and considerable component of the cost).
                            Thanks for the update Guy.
                            MY10 S3 3dr
                            • Good call BY,
                              Wouldn't be the first time that has happened during a service.
                              • Thanks for the quick responses
                                i shall check the oil filter this evening
                                Am i right in thinking the oil filter is located on the bottom side of the engine (behind the plastic coverings?) and accessed from underneath?
