It seems to be a trend; you experience the shudder in 2nd, they update software. It looks good for a few days or weeks then shudder comes back and they replace the clutch pack. This gives you a few weeks of joy until you lose drive completely, needing the mechatronics replacement.
I noticed that ever since my clutch pack was replaced the shudder in 2nd was gone, but it appeared, ever so slightly, in the first gear. And the car became a little unpredictable. Most of the time it would take off and accelerate nicely, but every so often it would act a bit crazy, like, you take off in first, it goes smoothly into 2nd but then gets stuck up to 4000 rpm to go 3rd. Sometimes again it would take off in first and wouldn't switch to the 2nd until you reach high revs. 5 minutes later it would act as normal.
I read somewhere that the VW in USA has recalled the 2009 DSGs because of the fault that is also becoming so obvious here, but VW Aus doesn't want to know about it. I'll find the article.
I had a chat with the mechanic today and he said that there are 2, or rather 3 DSGs.
1 - Prior to 2009, so called wet DSG, something of an oil-filled box
2 - The dreaded 2009 DSG with the Mechatronics that is failing en masse
3 - The same 2009 DSG but with a different mechatronics that is apparently 'perfect'
When I took my Golf to have the clutch pack replaced they gave me a loan car, a brand new Jetta. I can't tell you how beautifully that car drove, the DSG was as smooth as it possibly could be. It was sooo noticeable I was driving up and down Brisbane for almost an hour.
The guy today explained that Jetta has the new type mechatronics,the one I'll be getting.
